Rookie with major dpf delete problems. Help please - Ford Powerstroke Diesel Forum
post #1 of 4 Old 05-21-2014, 07:06 PM Thread Starter
Hi all,
I just installed a dpf delete kit on my 2008 F-250 6.4, I used a SCT X4 tuner and it worked fine for about 15 minutes and then it began attempting to clean filter...Resulting in horrible white smoke. Now when I shut it off it also is not registering the key and not allowing it to start, Any ideas what might be causing these problems???
2008superduty6.4 is offline
post #2 of 4 Old 05-21-2014, 08:43 PM
jcook933@gmail.com's Avatar
Did you get the x4 with customs tunes or are you running canned tunes from SCT. I don't believe the x4 is delete capable without custom tunes.
BEASTPSD
jcook933@gmail.com is offline
The Following User Says Thank You to jcook933@gmail.com For This Useful Post:
2008superduty6.4 (05-22-2014)
post #3 of 4 Old 05-22-2014, 07:40 AM Thread Starter
Thanks for the reply, I just used the tunes that came on it, where would I obtain custom tunes? SCT?
post #4 of 4 Old 05-22-2014, 07:59 AM
There are a lot of different places that offer custom tunes, quicktricks, innovative diesel, rudys, and gearhead to name a few. Sounds like your truck might be stuck on infinite regen do to the delete without a delete tune. I'd do some more research on here as far as that goes and I'm sure someone else will chime in. Good luck
BEASTPSD
Tags
6.4 , dpf , dpf delete
