6.0 Over Rev Shutdown and No Start-HELP! - Ford Powerstroke Diesel Forum
post #1 of 1 Old 05-21-2014, 04:50 PM
MarkEdwardAllen
Guest
Posts: n/a
Quoted: Post(s)
Unhappy 6.0 Over Rev Shutdown and No Start-HELP!
I have an 06" F550 w/ 153K miles that I put a dump bed on and have sunk more money then I care to into the engine - i.e. new turbo, new exhaust, new injectors, and changed all the fluids and filters. Anyway, I have run out of time and money to work on it and just do not ever use it so I took it out for a drive before I put it up for sale. It started right up and ran perfect but on the way home I ran the RPMs up to about 4K in 2nd gear (standard trans) and the engine just shut off. I barely got it off the side of the road trying to figure out wahat just happened and traffic all around. Now it just turns over with no start. I have read multiple suggestions, watch many videos on youtube and I have check all the fuses (they are good but I do not know how to check relays and whether maybe one is bad), I can hear and feel the fuel pump running and the injectors all adjusting and that vacuum thing on the passenger side over the wheel behind the battery running, and I also removed the fuel filter and turned the engine over and there is fuel. I also removed the oil filter and turned the engine over and the oil builds up steadily in the enclosure. I do not know what else to try and I can't haul the tank around to get the codes checked (if any) and do not have anymore money to put in it. I just want to sell it and break even and the stupid thing should be running top notch. PLEASE HELP! mark_edward_allen@yahoo.com
