03 6.0L had HPOP Replaced low BOOST now - Ford Powerstroke Diesel Forum
post #1 of 4 Old 05-20-2014, 10:55 PM Thread Starter
Exclamation 03 6.0L had HPOP Replaced low BOOST now
hii i know this is my first post but i need some help bad.... I just had my 2nd HPOP installed within 5000 miles now on my 03 6.0L and this time it is only getting up to 7lbs of boost (with bullydog on extreme even) and i can hear it hissing not the typical turbo whine... supposed to be leaving on a trip and cannot figure this out! any ideas?
03f3506L is offline
post #2 of 4 Old 06-23-2014, 01:07 AM
you either have a bad map,air mass or hole in the intercooler boots.
switch map from another truck if possible if you do not have a scanner and same on air mass.
have a friend you trust brake torque the truck and feel around on the hoses and pipes.
hope this info helps..
fatbastardf350 is offline
post #3 of 4 Old 06-23-2014, 01:08 AM
check fuel pressure as fuel dictates boost....sorry it's late.
post #4 of 4 Old 06-25-2014, 08:45 AM
Check the Y pipe to verify it isn't leaking. That clamp can be tricky to get on. Did they put a new IPR valve on?
DieselBreathDude is offline
