HELP!!!!!!!!!!!!!!!!!! - Ford Powerstroke Diesel Forum
Old 12-29-2008, 03:21 PM
Send a message via MSN to justafarmtruck
2002powerstroke. f 350 drw cc long bed 4x4
put chip in all is fine ran a few times then started to put gauges in wont start just cranks cleaned board put back in same then some fuses blown changed those
did i tap in wrong wires or what why wont it start and just crank!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!?????????????????????????????
Old 12-29-2008, 03:25 PM
come on boys ya gotta have some thing
Old 12-29-2008, 03:27 PM
not sure man, but im sure someone will be around to tell ya! my chip went in fine bu i dont have guages yet
Old 12-29-2008, 03:29 PM
electrical gets me everytime! did you unplug anything when you were doing your gauges? how far did you get on your gauges? what chip?
yeah we had the chip in fine no prob.s then shut off to do gauges after a few runs on and off with it and now wont start after the gauges but it could be in the wrong wire so removed all the wireing for the gauges and it wont work please help took the chip out btw
Old 12-29-2008, 03:31 PM
nothing unhooked went in to a bigger brown wire with orange stripe right along the cab on the fire wall unhooked it all so everythings stock just cranks and cranks
someone else will be able to help you better then me. but your sure you didnt bump anything or unplug somethin when doing this.
Old 12-29-2008, 03:35 PM
how did you tap into that wire? i know which one your talking about. did you check the fuse links? not sure if that would have anything to do with it just throwing ideas out there
went threw it all dont see any thing
Old 12-29-2008, 03:36 PM
Location: Little Rock Air Force Base,Arkansas and North Augusta,South Carolina
Did you put the chip in with the key turned in the ignition?
