NEED SOME HELP PLEASE!!! - Ford Powerstroke Diesel Forum
post #1 of 2 Old 05-20-2014, 06:26 AM Thread Starter
Angry NEED SOME HELP PLEASE!!!
OK, so driving down the road and truck acts like it starved for fuel and shut off. Towed home plugged up the scanner, no codes. So, opened data stream and everything is perfect, fuel 57psi, ipr, icp good, ficm 48.7vdc, so I get on here and search and search for days. STUMPED!! Now I know its not good but if you spray silicone for a little start jump it will fire right up and run for a few mins and then cut back off with no start until you do it again. Couple of friends are saying HPOP but the icp wouldnt be getting to 585 psi if the HPOP was bad right? or wrong? Any ideas?
04 F250 CCSB, Early 6.0, EGR Delete, Sinister Coolant Filter, 4" turbo back with MBRP 6"tip, SCT X4 with a couple tunes from Eric @ Innovative Diesel
PWiley is offline
post #2 of 2 Old 06-26-2014, 12:44 PM
What is the ICP on start?
DieselBreathDude is offline
