2003 7.3 F350 cranking but won't start, throwing codes - Ford Powerstroke Diesel Forum
post #1 of 5 Old 05-16-2014, 12:44 PM Thread Starter
So I have been working out of state & just got home last night. Truck hasn't been started since Monday. Went out to start it today. Started fine, backed up a couple feet & it died like the key was turned off.
Came back to it a few hours later with a new CPS & it cranked but didn't start at all. Installed the new CPS, but still the same. The wait to start light does come on.
Batteries are good. I can hear the fuel pump running. Comes back with basic codes 1316 and 1670 which I understand are IDM codes, but don't necessarily mean anything.
Murphy's law: Friday afternoon and the truck I would normally pull stuff with is stuck in the driveway. Short of calling a tow truck, I don't really have a way to get more in-depth codes--and I really am too early to call for that kinda help if you know what i mean...
Any advice would be welcome!
Jason
Jackson, MO
Last edited by fireman1; 05-16-2014 at 12:59 PM. Reason: left out info about the wait to start light
fireman1 is offline
post #2 of 5 Old 05-16-2014, 01:15 PM Thread Starter
Checked the relays to IDM and all are good.
Just read back thru some other posts and see that I should start taking apart valve covers & check the wire harness....guess that's what I will be doing this tonight & tomorrow before I head back out of town since the wife's van is acting up too and she needs to have a backup as nothing seems to be fixing it even though I broke down and took it to the shop today---they are completely stumped on it.
fireman1 is offline
post #3 of 5 Old 05-16-2014, 04:14 PM
Quoted: 157 Post(s)
Feedback Score: 3 reviews
This is where you really need a diagnostic tool that can do a buzz test are query the IDM for the codes it might generate afterwards (that's what the 1316 is trying to tell you, it simply means the IDM sees a problem and needs a buzz to further resolve codes and point you where to go next)
This could be a UVCH connector issue (thru the valve covers) BUT, this engine will actually start & run on 4clys so, the likely hood BOTH went at the same time is pretty slim. Chances are this is an IDM problem (although without a scanner it's just a WAG) and, without the proper tools, the next-best move would be to try and find someone you could swap with as a test (Any 7.3 IDM will do).
You know anyone nearby you could ask that of?
NoRalPh is offline
post #4 of 5 Old 05-17-2014, 07:23 AM Thread Starter
I do have a buddy with a 7.3. Is there any chance of killing his if I put it on mine?
fireman1 is offline
post #5 of 5 Old 05-17-2014, 11:47 AM
Quoted: 157 Post(s)
None....
IDMs fail because of Water (mostly, their seals fail and because of where they're located they get rainwater in them ~ shake yours and see once you take it out ) and, like all electronics - Heat.
NoRalPh is offline
