truck ran poorly now won't start? - Ford Powerstroke Diesel Forum
Old 12-26-2008, 04:00 PM
left the movies last night and the truck started up just fine but when i tried to accelerate and it just about died and the check engine light came on. I was able to nurse it home going about 10-15 mph but it would not go any faster. I plugged it in all night went out to start it this morning and it tried to start but was really rough sounding tried for about a half hour and nothing so I check the HPOP level and topped it off. checked glow plug really and it is giving good voltage. I have unplugged the ICP (or so i think, driver side valve cover toward the front) but still nothing. Since the check engine light has gone off, I do not have the tools to read codes, i have a battery charger on it right now so i have good voltage at the batteries as well.
1999.5 f250 7.3 with hypertech programmer and edge attitude both of which are off..... i have re-programmed the computer to stock still nothing....
thanks for any sugestions......
Old 12-26-2008, 04:09 PM
psd
it sounds like fuel problems
Old 12-26-2008, 04:12 PM
I pulled the fuel filter and it was full no gel replaced it not to long ago.....plus it was puffing black smoke when i was trying to start it
Old 12-26-2008, 04:15 PM
how do you tell if the IPR is bad?
Old 12-26-2008, 04:18 PM
Pointless Poster
id try cps. cam position sensor.
Old 12-26-2008, 04:21 PM
is there a way to test or do I have to start buying parts and trying them that way? If I could read the codes would they be able to tell me?
Old 12-26-2008, 04:33 PM
psd
yes and no some codes will show up but for a O-ring leaking oil by no.
its always good to clean and change o-rings on ipr valve. are you using the right motor oil ?
Old 12-26-2008, 04:55 PM
if the cam sensor was bad then the tach wouldn't register while cranking right? my tack moves
I'm using 15-40 valvoline
Old 12-26-2008, 05:13 PM
could be your idm module or injector harness under the valve covers. will your hypertech read any codes for it?
Old 12-27-2008, 12:12 PM
I just replaced the cam sensor and unplugged all the egde connections and still nothing my hypertech does not read codes........
