96 F350 INOP NO START - Ford Powerstroke Diesel Forum
Old 12-24-2008, 11:43 AM
Hello been reading here for awhile 1st post. My truck blew fuse #22 disconnected bowl heater. Now fuse ok but truck wont start. Cranks good but wont even attempt to start. Removed filter cover & filter, lift pump working,fills bowl. G/P relay checks good. Checked connectors at valve covers all clean. Disconnected icp and tried to start no help. Put a friends scanner on it pulled codes P1163, P1167 and P1746. Any ideas.
Old 12-24-2008, 08:04 PM
Send a message via MSN to wyoming
Is it cold there? I just had the same problem. I put a blow dryer on my HPOP. That got it started. Then took it and had the oil changed to a lighter weight oil. I dont know if it was part of the problem also but my EBPV was stuck too, I disconnected it tonight
Old 12-25-2008, 08:14 PM
yea its in the low 30's. I plugged it in and let it sit for few hours still no good. I need to find out about those codes. I'll try the dealership tomorrow and see what they say.
Old 12-25-2008, 08:23 PM
hey wyoming what % of tint you got on the front doors? ive been wanting to tint mine front doors. Back and rear window are 5% but i they look a little dark for night
Old 12-25-2008, 09:14 PM
Not sure about the codes, but when that fuse blows it shuts off your fuel pump so sometimes it takes a bit to get fuel back into the motor because it is like running out of fuel. Did you try more than once. With the bowl full I would think the fuel would be getting there after a couple times of cranking.
Old 12-26-2008, 07:20 PM
yes i cranked it for awhile, had to put batteries on charge. it just seems like its getting no fuel to injectors. how do i test the ipr?
Old 12-29-2008, 03:57 PM
I got er fixed. Found idm pwr wire chewed thru by little rodents. Fixed damaged wires and truck fired right up. Thanks for the help.
