blown 30 amp fuse 99 F350 Help!! - Ford Powerstroke Diesel Forum
Old 12-22-2008, 02:58 PM
Hey I'm at work and my Captains powerstroke keeps blown the pcm fuse 30 amp under the dash. Truck will run fine for a min the stop and the fuse is blown again. Any suggestions???
Old 12-22-2008, 03:01 PM
Almostdunfukinwidit
Check the fuel bowl heater for a short
Old 01-02-2009, 01:44 PM
i agree... there is a short somewhere. If you have had any fuel or oil leaks, check the harness near the leak. the fuel/oil will sometimes eat at the connections and you will have wires touching.
Old 01-02-2009, 09:20 PM
It was the fuel bowl heater thanks guys for the help!!!!!
