Injectors 7.3 1997 powerstroke - Ford Powerstroke Diesel Forum
Old 12-20-2008, 06:32 PM
Need help
Will one injector shorted cause the other ones on same bank to not fire ,John
Old 12-24-2008, 06:40 AM
Check the Valve cover gasket.
Old 12-24-2008, 10:48 AM
Havr replaced gasket and UVC harness just one #4 is shorted make 2 6 &8 not fire i can unplug # 4 will run on 7 cylinders fine
Old 12-26-2008, 06:41 AM
Thats Mr. Oil Leak.....
I don't think the injector will cause the whole bank to not fire. Sounds like a short somewhere. check the main harness where it passes over the top of the driver's side VC and make sure nothing has rubbed through there.
Old 12-26-2008, 07:31 AM
shorted UVC
Thanks the New UVC was bad now running like a top.John
