possible starter shot - Ford Powerstroke Diesel Forum
Old 12-14-2008, 07:17 AM
99 f350 7.3l when trying to start the starter just makes a clicking noise dont know if the starter is toast or not
Old 12-14-2008, 07:24 AM
you can check it with a test light, if the starter is getting power from the battery and the solenoid is getting power from the starter relay when trying to start and you have a good ground at the starter/engine block it should start if the battery's are in good condition.
mine did the same thing and i took it off, dissasembled it for inspection. it fell into a million pieces when i took the bolts out...lol
where you stationed Marine ?
Old 12-14-2008, 07:29 AM
im staioned in virginia i checked the seloinoid and the batteries all seems good
Old 12-14-2008, 07:35 AM
The solenoid on the starter or the one on the passenger side inner fender ? make sure your getting power and ground at the starter. If so then your gonna need a starter.
Look around, after I bought mine I found a sweet deal on the exact brand as the original equipment for half the price.
Old 12-14-2008, 07:38 AM
the one on the inner fender was not aware of the one on the starter
Old 12-14-2008, 07:41 AM
Powerstroke Techie
Sounds like a bad connection to me, but it could be the starter, those things are expensive so I'd check batteries and connections out real good before replacing the starter.
Here is a pic where you can see the starter and solenoid hanging from the red wire
Old 12-14-2008, 07:43 AM
the starter has a solenoid on it also, should have a large wire that supplies Battery voltage and a smaller wire that is energized (min of 10V) when the ignition is in start position.
Old 12-14-2008, 07:47 AM
but it only does it some times would that be the sign of a solonoid going out/?
