alternator fire - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 14 Old 04-22-2014, 09:27 AM Thread Starter
Redz284u's Avatar
Quoted: 9 Post(s)
alternator fire
so I was going to get the truck washed, but 2 blocks down the road smoke out of the engine bay.
pulled over popped the hood and the alternator is on fire. extinguished it self out but the burnt electrical smell.....sheesh..
anyways, could I potentially drive the truck to the dealer, or will it catch on fire again????
Redz284u is offline
post #2 of 14 Old 04-22-2014, 09:40 AM
c69ss396's Avatar
Unplug it and disconnect the main wire off the back, be sure and tape it up real good. Your alt has a internal short to ground, it will catch again! Even by just letting it set there if you still have the batts connected...
Sent from AutoGuide.com App
Dieselsite/Strictlydiesel Efuel, Baby Swamps, Adrenaline HPOP, D66 w/1.0 Housing, ww2, International Uppipes, Swamps tunes, Swamps IDM, Tymar Intake, 5in Exhaust, 203* T-Stat, Aluminum Radiator, 6.0 Fan, Dieselsite Coolant filter, Luk Clutch
c69ss396 is offline
post #3 of 14 Old 04-22-2014, 09:42 AM Thread Starter
Redz284u's Avatar
Quoted: 9 Post(s)
So unplug, wrap it real good, then I can drive it to dealer?
Redz284u is offline
post #4 of 14 Old 04-22-2014, 09:55 AM
c69ss396's Avatar
Yes once you have the all the wires disconnected and taped up.
c69ss396 is offline
post #5 of 14 Old 04-22-2014, 09:57 AM
c69ss396's Avatar
Your lucky you caught it, that's normally not the case....
c69ss396 is offline
post #6 of 14 Old 04-22-2014, 10:13 AM Thread Starter
Redz284u's Avatar
Quoted: 9 Post(s)
So it may have 2 alternators. I know I saw flames on the one from the passenger side top, right under inter cooler pipe. If I had a second unit, where would it be?
Redz284u is offline
post #7 of 14 Old 04-22-2014, 10:16 AM Thread Starter
Redz284u's Avatar
Quoted: 9 Post(s)
what is normally the case?????? could the whole car catch on fire because of this?????
Redz284u is offline
post #8 of 14 Old 04-22-2014, 10:24 AM
Yes! Truck out of warrantee.
If it's still covered let them come & get it.
letitsno is offline
post #9 of 14 Old 04-22-2014, 10:42 AM
c69ss396's Avatar
Yes the that would cause the whole truck to go up in flames. All it takes is one piece of plastic to catch fire and it's over but the crying....
c69ss396 is offline
post #10 of 14 Old 04-22-2014, 12:22 PM
Harley516's Avatar
if u got good insurance let it burn and start over.
Heavy_GD likes this.
Harley516 is offline
