truck wont start - Ford Powerstroke Diesel Forum
Old 12-07-2008, 12:03 PM
Send a message via AIM to blowinsmoke4life
Exclamation truck wont start
Just happened the other day i went to start my truck and i turn it to starting position and nothing not even a click. So i check the batteries and get them load tested one is jus fine the other isn't so i replace the bad one and nothing once again. So i have the starter checked it was bad too i get a new put it in and nothing. So i replace the neutral safety sswitch because befro hand i was startin it in neutral so i knew i needed to replace it soon anyways plus i had no back up lights so i get that replaced and nothing. So lastnight i get a start relay solenoid and a new starter ignition key and i still get the same result of nothing. I've checked voltage to the starter and the starter relay i dont kno wat else to do. so if anyone can plz help me it would be greatly appreciated
Old 12-07-2008, 12:14 PM
plz anyone that has even the slight idea
Old 12-07-2008, 12:16 PM
Pointless Poster
no clue. alternator maybe?
Old 12-07-2008, 12:17 PM
nope brand new alternator replaced last month thanx tho
Old 12-07-2008, 12:23 PM
Pointless Poster
hmm. thats all i got lol. hope you get it figured out
Old 12-07-2008, 12:40 PM
can someon plz help me out i really need the truck for monday i dont kno wat else to check
Old 12-07-2008, 12:44 PM
come on 188 ppl on here and none can help or even see if they can help
psd
did you check your maxie fuses
Old 12-07-2008, 12:46 PM
You may have got a bad switch or the wrong one from the parts store. Try useing a jumper wire to see if you can get it to start then you will know it's in the switch.
HTH
BOOSTBROTHER
Old 12-07-2008, 12:49 PM
what are those and where would i look for them. i checked my manual and it dont show a fuse for the starter or the starter switch
