2003 6.0 Dies while driving - Ford Powerstroke Diesel Forum
post #1 of 7 Old 04-07-2014, 05:46 PM Thread Starter
160K+
HPOP, FICM, 2 injectors, EGR Cooler, oil cooler all changed at about 150K.
Edge monitor, no power levels
When cold truck fires right up no issues, warm up go down the road and truck dies after about 5 min while slowing down for stop sign(no throttle input) WONT RESTART. Get truck to side of road let it sit(family goes to dinner) Come back Truck fires up, huistle it home.
Put truck in park idles fine, revs fine, FICM volt good, ICP .5-.6 while cranking(could be intermittent).
Put truck in drive and it dies and wont restart. This has happened about 5-6 times and each time truck goes a shorter distance.
NO CODES NO CODES NO CODES
any help? TIA
Not4show is offline
post #2 of 7 Old 04-08-2014, 05:20 PM
.5 volts of ICP is no good. You should see a volt or more with the engine idling. First, unplug the ICP sensor and try to restart after the thing dies. If it starts, replace the ICP sensor and connector. If it does not, I would think you have a HP oil pump that is worn out. The 2003 6.0L does not have as many places to leak HP oil as the later models, but the early pumps fail quite a bit.
winnersdieseltech is offline
post #3 of 7 Old 04-09-2014, 06:55 AM Thread Starter
Thanks, this is my nephews truck, has been going on for about 18 months, I just got around to start looking at it. When this first started it would happen like 1 once a month, then slowly got worse to where it is now.
The problem with the EDGE monitor on the 03 trucks is that it does not give ICP pressure, like it does on newer trucks. Only ICP volt, when it was running the ICP volt was over 1v, with just switch on it read .2v and crank no start was .5v.
I have a 7.3 with 280K that has basically been zero issues in the 14 years I've own it, and a 05 ex with a 6.0 and 140 on it. I guess I'll finally breakdown and get AE
Not4show is offline
post #4 of 7 Old 04-09-2014, 09:47 AM
One volt is about 580 psi. You need about that much to properly fire the engine
post #5 of 7 Old 04-09-2014, 12:28 PM Thread Starter
Thanks, looking to order the ICP and pigtail now.
Not4show is offline
post #6 of 7 Old 04-09-2014, 03:20 PM
And just so you know, looking at your monitor, Key On Engine Off, your ICP voltage should be near zero. If its .5 with the engine not running, that's where your problem lies, and the sensor and connector are a sure bet to fix it. If 1 volt is 580, psi, than half of that is 290. So the system thinks it already has 290 psi, and backs off the IPR, as PCM believes that you have more ICP than you actually do.
post #7 of 7 Old 04-10-2014, 09:45 PM
Dose that edge display IPR percentage if so you would need to have about 22% is where my truck idols and you dont want to see 85% for the most part ever even cranking over to fire
Farmboy162005 is offline
