07 f250 no start!! 0 icp reading? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 04-07-2014, 06:57 AM Thread Starter
Hi,
I have a 07 f250 6.0. While driving it for about 20 minutes it stalled in the middle of the road. The truck showed zero oil pressure on the gauge while cranking.
Purchased a scangauge 2.
KOEO
Ipr. 14.4
Fmp. 47.0
Syc. 0
Icp. 0
Cranking
Ipr. 77.6
Fmp. 47.0
Syc. 1
Icp. 0
Icp disconnected while cranking
Ipr. 51.0
Fmp. 47.0
Syc. 1
Icp. 1222
Please advise me as to what maybe the issue.
Thanks
robertjr314 is offline
post #2 of 2 Old 04-08-2014, 05:14 PM
If the gauge doesn't read oil pressure, its likely a base engine or oil pump concern. To verify oil pump operation, remove the oil filter. Depress the check valve in the bottom of the oil filter housing (black plastic button), and have a helper crank the engine over. The filter housing should fill very quickly. If it does not, and the oil level is ok, you have an oil pump issue. Not HP oil pump, engine oil pump.
winnersdieseltech is offline
