6.0 no start - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 17 Old 04-03-2014, 07:36 PM Thread Starter
Darezombie's Avatar
Angry 6.0 no start
Ok guy im at a loss. I have an 06 6.0 king ranch with 184xxx miles. It started fine this morning so i could move it but when i went out to start it again before i left for work it wouldn't start. It cranked fine as usual but just wouldnt start. this has happened to me before but it only seems to do it when its raining. I was just wondering if anybody has had something similar happen or had any ideas.
Darezombie is offline
post #2 of 17 Old 04-03-2014, 07:38 PM
B_router's Avatar
The guys on here will tell you that even a cheap monitoring system is crucial to determine 6.0 problems. knowing some additional info would be a huge help.
05 F-250 XLT extended cab short bed----Studs, Black Diamond Gaskets, oil cooler, Blue Spring, ScanGauge, EGR delete, PMM coolant filter, Ed's FICM, T-6 and CAT coolant......what will break next?!
B_router is offline
post #3 of 17 Old 04-04-2014, 05:29 AM Thread Starter
Darezombie's Avatar
well i have a mini maxx and i have no codes and all vitals are reading good. i went out this morning and it started so idk what causes it. i have good fuel and oil pressure. it did this same stuff about a month ago. i had bought the truck not to long ago but its not the first 6.0 iv had so i know the main things to look for but everything seems to be fine. it has a hard time starting untill its warm but then runs fine which makes me think the ficm might be going. the guy i bought the truck from took it and had the oil and fuel filters changed but they only changed the top filter but not the bottom so after i changed it, it ran alot better. when it finally stops raining im gonna pull the bottom filter again and see what it looks like.
post #4 of 17 Old 04-04-2014, 06:03 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
Can your mini maxx give you the ficm volts? Does the truck even turn over?
I would start out by checking your batt cable's real good. As in pull them off, wire brush the. and then reinstall with some of that cable seal anti corrosion paint. I don't know if that's gonna fix anything but at least you could rule that section out.
You said it has a hard time starting until its warm. Check your ficm volts. If at anytime they drop below 46 then ya your ficm has seen better days.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
The Following User Says Thank You to kinnisoj For This Useful Post:
Darezombie (04-04-2014)
post #5 of 17 Old 04-04-2014, 11:26 AM Thread Starter
Darezombie's Avatar
Lol thanks kinnioj that's good input. Yah it rolls over fine but just won't fire. It dose it intermitadly (I.e. It started this morning as it normally would.) and no the mini maxx has a narrow monitoring range so it dose the basics such as icp and temps as well as standard battery voltage. I'm looking into getting a scangaugeII for the long haul because I'd hate to have to keep tering into things relatively blindly. I'm gonna test the ficm this weekend if I can because that was the main problem on my last 6.0. Once again thanks guys I apreciate the help.
post #6 of 17 Old 04-04-2014, 11:32 AM
Teachagmech's Avatar
Quoted: 408 Post(s)
Garage
don't waste your money on a SGII. get the torque app. its cheap and works great.
that being said, how cold is it? does it smoke at all? what about after it actually does start? if your glow plugs aren't working, you're gonna have a hard time starting for sure. KY isn't always the warmest place on earth this time of year. if its raining, it may just be too cold to start.
Mike"Bustin' mine to feed yours"
The "Kerosene Queen"
2005 F-250 CCSB FX4 LARIAT 150K blue spring, coolant filter, DC Power alt. and
Teachagmech is offline
post #7 of 17 Old 04-04-2014, 12:39 PM
E99F350Stroker's Avatar
What part of south central Kentucky are you from?
Jordan
*Sold* Early 99 F-350 dually 4x4 6spd 7.3
*Sold 2000 F-250 4x4 ATS auto 7.3
1996 Dodge 2500 4x4 speed, 12 valve cummins, 283000, stock
E99F350Stroker is offline
post #8 of 17 Old 04-04-2014, 01:57 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
You can also look on you tube for how to test ficm volts video. If you have a simple volt meter it will show you how.
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #9 of 17 Old 04-04-2014, 06:46 PM Thread Starter
Darezombie's Avatar
E99F350Stroker i live in taylor co. and work in marion co. so im only about an hour away from where your at. Anyway i know its not the glow plugs and i know how to check voltage on the ficm. the truck i had prior to this one was an 05 6.0 and iv been down that road lol. i ended up changing the glow plugs, timer, and harnesses before i finally tested the ficm and it was the problem. Teachagmech its 50s - 70s right now and back a few weeks we had a good amount of snow and she'd start right up. also no it doesn't smoke at all. i dont know if its related for sure but when its running it takes for ever to get to full temp and it misses until its around 160-175 on the oil side. i plan to take it to someone if i don't figure something out soon. iv learned to be patient with the 6.0 and im learning more and more from this site and all of yall.
post #10 of 17 Old 04-04-2014, 07:03 PM Thread Starter
Darezombie's Avatar
Ohh also I have an iPhone so do thay have the torque app for it? Tell me more. Lol
Tags
6.0 , no start , raining
