02 7.3 Cranks no start - Ford Powerstroke Diesel Forum
post #1 of 3 Old 03-30-2014, 05:41 PM Thread Starter
lrazer's Avatar
Last night I stopped by my friends place, the truck was sitting for a few hours and when I went to start my truck, it would just crank and not start. I tried again this morning and it started cranking with nothing happening then slowly started to "build up" until it started. It seemed like the oil pressure to the injectors built up to the point where then it would start.
So I drove it to my shop shut it off and after about an hour I went to start it again and crank no start. I unplugged the icp sensor and still no start. Plugged sensor back in and scanned the truck with AE.
I got a P1212 and P1280 and here is the scan data while cranking:
I dont know if this is related or not but for a while now when you first start the truck when it is cold it has the "romps" or surging at idle until you hit the throttle to smooth it out. Sometimes it is so bad that it will die unless you hold the throttle up until it can catch itself. None of my other 7.3s do this.
The truck has new injectors from P.I.S. about a month ago.
The ICP sensor was replaced about 2 months ago.
15 F350 RC 4x4
14 F550 CC 4x4
05 2500HD CCSB 4x4 Duramax
02 F250 CCSB 4x4 ZF6 Swap
- aFe Stage II, 4" TB Exhaust, P.I.S. 160cc/30%, GTP38R, T500, DP-Tuned
- ITP Overboost Annihilator, Regulated Return
02 F250 CCLB 4x4 (Parting Out)
02 F250 SCSB 4x4
- Ford AIS Intake, 4" TB Exhaust
- ITP Overboost Annihilator, DP-Tuned
01 F250 SCLB 4x4
- DIY Intake 4" TB Exhaust
99 F550 RC 2x4 ZF6
lrazer is offline
post #2 of 3 Old 04-01-2014, 07:23 PM Thread Starter
lrazer's Avatar
I think I found the problem, had a broken o ring on the #2 injector.
I was watching the icp pressure while cranking and if i cranked it long enough (20-30 sec) sometimes it would build enough pressure to start (500psi).
15 F350 RC 4x4
14 F550 CC 4x4
02 F250 SCSB 4x4
01 F250 SCLB 4x4
99 F550 RC 2x4 ZF6
lrazer is offline
post #3 of 3 Old 04-03-2014, 06:52 AM
timmyboy76's Avatar
great find, man. Check hpop level, oil level, if you can read lpop pressure, get a reading...
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
