2001 7.3 turbo f350 - Ford Powerstroke Diesel Forum
post #1 of 20 Old 03-30-2014, 08:55 AM Thread Starter
2001 7.3 turbo f350
Hey guys in new here but need help. 2001 F350 single wheel 7.3 turbo. will idle all day long but as soon you get in and go it will go for a half a mile and do fine. Then it will not rev past 2500 rpm and wont run faster than 40mph. pull over to the side of the road let it idle 15 min and it will do the same thing half a mile its good then just does the same thing. HELP thanks. Truck is 6 speed if that helps.
Thanks in advance!!
xclreaper is offline
post #2 of 20 Old 03-30-2014, 09:26 AM
Quoted: 184 Post(s)
Feedback Score: 3 reviews
When's the last time you put a Fuel Filter in it?
What's the status of your CPS? If your '01 does NOT have a Trans Temp Gauge in the Cluster, make sure you see the Tach Needle rise a little bit while cranking to know it's working (if it Does have that gauge it won't anyway)
Is your tank above 1/4?
Have you ever done the "Hutch Mod"? (removing the screens in the tank that can clog)
NoRalPh is offline
post #3 of 20 Old 03-30-2014, 09:33 AM Thread Starter
i just bought the truck. fuel is at half tank. he said he had a diesel mechanic look at it and said it was the control solenoid for the wastegate. Other than that im not sure bud im sitting on the side of the road
post #4 of 20 Old 03-30-2014, 09:38 AM Thread Starter
Just tring to trouble shoot myself and reading some on here would the ebpv be stuck closed and the truck going into limp mode "if it has one" building to much boost? it spools up
post #5 of 20 Old 03-30-2014, 10:39 AM
Quoted: 184 Post(s)
If the wasetgate was closed, you would have low power, might limit revs, BUT you'd hear the restriction as an, unmissable, Hissing sound from the tailpipe (been described as that, LOUD, "Jet Engine Noise"). There isn't really a "Limp Mode" that would be applicable to that either...
You might have a Fuel Delivery problem. Are you "stuck"? If it won't start & run you can check for fuel in the Fuel Bowl easily though. Open the Hood, the round black cap in the front/center of the motor (5" around maybe) is the fuelbowl (filter housing). Look above the pass ft tire, you'll see a 3/8" metal tube, against the motor that ends there, it's the drain for the bowl (yellow lever you slide to the side). Get a cup, open the lever, drain the fuel bowl, look at the fuel, close the lever. Then, turn the key to the ON position (should hear the pump) for 15 secs. Drain the fuel bowl again, whaddya got?
NoRalPh is offline
post #6 of 20 Old 03-30-2014, 11:49 AM Thread Starter
Yes im stuck. Truck is not building boost at all. You can see it spinning so it's not locked up but no boost. Any idea
post #7 of 20 Old 03-30-2014, 12:35 PM
Quoted: 184 Post(s)
OK so, it Starts & Runs?
You just have No Power?
Idles smooth?
No "Jet Engine Roar"?
You're familiar with the Inter Cooler plumbing? There are 4 rubber connectors (2 Blue 2 Red) that connect those 3" hard pipes from the Turbo, down to the IC (on the drivers side) though the IC and out (on pass side) and up to the spider (intake plenum Y). If one of those has blown-off you would have trouble building boost. Look at them...
But the PO was familiar with this problem and had it diagnosed as a Wastegate issue? If so I'd think that ROAR would be obvious.
NoRalPh is offline
post #8 of 20 Old 03-30-2014, 12:50 PM Thread Starter
Starts idles fine. Doesn't roar all pipes are tight
post #9 of 20 Old 03-30-2014, 12:51 PM Thread Starter
If you hold it at 2k rpm it will drop off and come back up repeatedly like a very slow bounce off the limiter if that makes since
post #10 of 20 Old 03-30-2014, 12:53 PM
sbluke55's Avatar
Quoted: 624 Post(s)
Garage
I would try to pull the red tube of the waste gate and see what happens. If the solenoid make it stick open it won't build pressure. Just a thought. FYI It won't cause any damage either.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
