electric fuel pump help!! can't figure somethin out - Ford Powerstroke Diesel Forum
Old 11-29-2008, 07:42 AM
ok i am trying to put the new pump on but i can't get the old clip thing inside the fitting on the pressure side off???is their a trick to this? special tool? it is a little metal thing it turns inside the fitting and holds in the line on the pressure side of the pump..thanks
Old 11-29-2008, 07:50 AM
Jon
Guest
Posts: n/a
Yeah
theres a special line tool for that. I dont know who has one other then tool trucks. Thats where I got mine. I'm sure you can order one. I have asked several parts places about them and had no luck. If you could make something that you could roll around the line then push up into the connector you may beable to pop it loose.
psd
yes it is a tool from ford.but you can get it off with two small screw drivers.push it in the fitting and there is a wire ring in there to hold it together
push the wire ring back and leave the screw drivers in there and pull apart
Old 11-29-2008, 08:07 AM
Ole White
I found that tool at my local Napa they had either a plastic set with diff. sizes or an all-in-one metal one that would do several sizes to fit diff. fuel line connectors
Old 11-29-2008, 08:08 AM
Jon
Guest
Posts: n/a
Cool
The napa here didnt have them. I've got the aluminum ones.
Old 11-29-2008, 08:12 AM
Ole White
Yeah thats the same ones I got actually when I replaced my pump I just unscrewed the fitting out of the FP that the quick connect is attached to and screwed it back in to the new Walbro 392 pump
Old 11-29-2008, 08:15 AM
psd
MAN you guys do it the easy way.but i didnt know napa sold the tool,thanks
Old 11-29-2008, 08:39 AM
cj41foleyisathief
napa autozone pepboys ect ect
Old 11-29-2008, 08:45 AM
Ole White
No problem at least my Napa does Jon says his doesn't who know's
Old 11-29-2008, 05:28 PM
yea the alum. Napa ones look just like the ones in my Matco kit.
