Fuel cutout, studdering, will not restart - ICP IPM? emergency, need truck asap - Ford Powerstroke Diesel Forum
post #1 of 14 Old 11-28-2008, 11:20 AM Thread Starter
RL1
Was driving a couple days ago, decided to get into the pedal and the truck suddenly started to hesitate like it was starving for fuel. Tank was low, I quickly switched to the rear tank and after 10 seconds no difference. Truck stalled as soon as I lifted off the pedal and wouldn't restart. Multiple times cranking and nothing. I didn't notice any white smoke while cranking either. Decided to turn the key forward until the GP's went out (I have an led light installed on my dash wired directly to the GPR so I know they are definitely out) Waited 15 seconds after the led went off and gave it a shot of either. After a couple cranks the truck fired, had to keep pedaling the gas and brake to keep it running because it ran like it was starving.
Smoothed out above 2k anything below and it felt like it was down a few cylinders. I was 1/2 mile from home with no where to turn the truck around so I drove it back in reverse. I had to pedal the gas and brake to keep it running and get it up the driveway into the garage. Once I stopped it died, truck wouldn't fire, barely any smoke. I needed to replace the lift pump anyway. I did it last night and the truck refuses to fire. It took much longer than expected to fill the bowl also. Had I known anything about the IPR then I would have taken it out and serviced it while I had easier access. I did some reading today and discovered other possible problems like the IPR ICP, however I do not have any scan tools or real diagnostic equipment.
I need to get this truck back up asap, I need it everyday for work. I found this relating to the IPR New Page 0 I assume it is under the FRP, towards the front drivers side of the motor with the hinge type wire lock on the plug?? I assumed CPS from all the stories I've read also, but if that was true I assume I wouldn't have gotten the truck fired back up after its initial stall.
Brand new batteries, GP's and fuel filter - tach moves a few hundred RPM's while cranking also.
Thanks for the help, I've done some research and this is what I've narrowed it down to - any help and suggestions would be great.
- Keith
RL1 is offline
post #2 of 14 Old 11-28-2008, 11:28 AM
cchase's Avatar
The CPS could come and go.
I would also check the valve cover wire harness.
what kind of shape is your fuel pump in? make sure that is flowing correctly
On vacation from a truck for a year or...
Looking at 6.4s Moving in a few months then hopefully buying my dream truck!!!
Driving an Audi till then...
but at work I drive
16 E-450s 7.3 powerstroke Ambulances
7 Duramaxes
1 GMC Kodiak Ambulance
NO CUMMINS.....
cchase is offline
post #3 of 14 Old 11-28-2008, 11:35 AM
Ryan Rønning's Avatar
Quoted: 6 Post(s)
Check your valve cover harnesses. Experience proves this is usually the culprit. Happened to me once and my dad’s 94 3 times. Very common. If the connection gets loose it will shut down all 4 injectors and glow plugs in that bank. Truck will run like dog **** if at all!
Project Frankenstein
1997 Ford F-350, Dually conversion, Cobra 29 LX CB, 12000 watt converter, All LED lights, TW tunes, 4" DP, Napa Intake, coolant filter, 140cc Injectors and lots of running lights.
Originally Posted by XPLOSIV View Post
Thanks. I'll give er a good wackin in the morning.
Ryan Rønning is offline
post #4 of 14 Old 11-28-2008, 12:07 PM Thread Starter
RL1
I just did, unplugged the 4 GP plugs, placed dielectric in each. Made sure all other connectors relating to harness were snug and nothing. Dont have anyone here with me to move the harness around while cranking. trying to locate the ICP, was told drivers side front oil line behind ac compressor??
RL1 is offline
post #5 of 14 Old 11-28-2008, 12:26 PM Thread Starter
RL1
Unplugged the ICP, started right up, throwing black smoke and ran like dog crap
RL1 is offline
post #6 of 14 Old 11-28-2008, 12:29 PM
Quoted: 6 Post(s)
Yep, it’s right there. 3 wires coming out. Forgot to ask the year of the truck but on mine the wires are grey with red strip, blue with green stripe and I can’t remember the third color but if you find those two with a third you've found it.
post #7 of 14 Old 11-28-2008, 12:31 PM
Quoted: 6 Post(s)
It ran with it unpluged? It shouldent!
post #8 of 14 Old 11-28-2008, 03:04 PM Thread Starter
RL1
Yep, ran at it's default at 725psi. Apparently if it runs with it unplugged it indicates a bad ICP or problem with the wiring.
I replaced the ICP today and it wont run, will with it unplugged though. Checked ohms and voltage, this is what I got
ECSD - Injection Control Pressure (ICP) Sensor - 1994-1997 Power Stroke FAQ
I'm seeing 2 ohms in connector A, infinite in C and B - Voltage reads 0.04 in A and C - B is reading 5.10
RL1 is offline
post #9 of 14 Old 11-28-2008, 03:21 PM
Cynic
Dirk's Avatar
The pcm will just kick to a default pressure.
Unplugging the ICP will default to 700-900psi. At idle, that should not cause it to idle poorly. Or did you drive it without it plugged in?
Is there oil inside the icp sensor connector? Is the harness/connector chewed up?
Best Car & Motorcycle Insurance | Auto/Moto Protection Today | FREE Trade-In Quote
Voluntary Banishment: Knowing when to leave.
Total Diesel Performance\Unlimited Diesel Performance\Diesel Innovations\BTS\Terminator Engineering\Swamp's Diesel Performance\Black Widow Diesel\Calvert Racing
Dirk is offline
post #10 of 14 Old 11-28-2008, 04:07 PM Thread Starter
RL1
No I didn't drive it with it connected. After repeated attempts to start it in the garage with no luck I unplugged the ICP and it started but ran piss poor. I did just replace the lift pump also because I assumed that was the problem so that could be why it was idling like that. The harness and connector look great. Short of pulling the loom off the wire bunch I don't see anything wrong. And no oil inside the connector.
RL1 is offline
