please help. 2006 F250 light gray white smoke then ran fine - Ford Powerstroke Diesel Forum
post #1 of 7 Old 11-27-2008, 03:37 PM Thread Starter
On vacation 500 miles from home and truck lost power started smoking white light gray. Lasted about 5 min. and picked up and ran fine. Coolent level same as when I started on trip oil level same not overheating changed fuel filters 2 weeks ago and oil last week. Need advice no check engine light no mods truck is bone stock with 70,000 miles I added cetane boost after smoke cleared and went 30 miles to campground with no trouble. I am pulling a light weight camper of only 5000 pounds.
ewwilborn is offline
post #2 of 7 Old 11-27-2008, 03:45 PM Thread Starter
Forgot to add lost all power when smoking rpm's up down pedal had no effect.
post #3 of 7 Old 11-27-2008, 06:01 PM
Rice Hunter
Diesel Freak's Avatar
You may need to pull your EGR valve out and service it.
Keep an eye on your boost gauge also. The vanes in your turbo may be sticking.
Mine started out with white/grayish color ..... Replaced exhaust back pressor sensor. Cleared up for 3 months. Replace head gaskets. Cleared up for a few months. Removed EGR Cooler. Been clean for 3 months.
Lloyd Vice Director of Virginia Strokers
2006 F350 6.0L SuperDuty Lariat 4x4
Magnaflow 4" S.S. Turbo Back, Lost Cat, 5" S.S. Tip
Custom Tuned SCT
6" Fabtech 4-Link Suspension- Dirt Logic Shocks-Dual steering Stabilizers
S.S. Brake Lines
Fumoto oil Drain Valve
Accufab Polished Elbow
BFG 37"x12.5"x18" Load "D" All Terrains
ARP Head Studs
EGR Delete
'03 Turbo Swap
Diesel Freak is offline
post #4 of 7 Old 11-27-2008, 06:02 PM
ADMIN AND TECH
SCUFFY828's Avatar
ill agree with loyd , sounds like egr valve hung open to me
ITS STOCK
SCUFFY828 is offline
post #5 of 7 Old 11-27-2008, 06:05 PM
Jon
Guest
Posts: n/a
Quoted: Post(s)
Well
Since nobody has mentioned it I'd say the EGR valve hung open for a bit! Check that!
JK What they said! LOL!
post #6 of 7 Old 11-27-2008, 06:08 PM
Rice Hunter
Keep an eye on that color of smoke also. Hoping it doesn't turn blueish. Yup ...... swapped out the turbo. Cleaned up except SOOT
Custom Tuned SCT
S.S. Brake Lines
ARP Head Studs
EGR Delete
'03 Turbo Swap
post #7 of 7 Old 11-27-2008, 06:28 PM
ADMIN AND TECH
SCUFFY828's Avatar
ID OF NEVER THOUGHT ABOUT THAT EGR VALVE JON
ITS STOCK
