Harder to start the colder it gets - Ford Powerstroke Diesel Forum
post #1 of 7 Old 11-25-2008, 05:57 PM Thread Starter
MTH
I have a 99 250 7.3 L. I hope some one can help. The colder it gets, the harder it is to start but not the normal. Starts getting hard around 40F. If I disconnect the batteries and hook them up right before starting it's fine. If I let it set overnight with the batteries hooked up; it starts if it is warm out but gets harder to start the colder it is. It dosen't matter how cold it is if I have the batteries charged and hook them up right before starting. When it is difficult to start, it starts cranking fine but quickly slows as if the batteris are dead. It has two new batteries 995cold cranking amps at32F. It pulls 23mA at rest I don't believe I have any stuck relays. Suggestions Unfortuantely, I can't afford to take it somewhere right now.
MTH is offline
post #2 of 7 Old 11-25-2008, 05:58 PM
starter going south?
Early 99 F350-Sold
01 Excursion-Sold
98.5 Cummins-Sold
02 F250- Stock
My Hero
Goose is offline
post #3 of 7 Old 11-25-2008, 05:58 PM
maybe a short on your ucvh's
Early 99 F350-Sold
01 Excursion-Sold
98.5 Cummins-Sold
02 F250- Stock
My Hero
Goose is offline
post #4 of 7 Old 11-25-2008, 06:03 PM
TurboSevenThree's Avatar
Well how low does your voltage go on the gauge while cranking? And it starts so hard because there are 8 glowplugs that take plenty of amps to work, then a large starter that takes a ton of amps, there's a reason there are those heavy amperage batts under there. Try letting the glowplugs on for a full minute instead of just when the wait to start light goes out, it'll have an easier time starting.
Old Truck: 00 F350 XLT DRW: basic first few mods. S&B, 4" straight pipe, gauges, CCV, EBPV and Wastegate line deletes, LED Sills, sweet custom headlights, smoked cab lights, Ventshades, Tint.
Traded in at 196k miles.
"Brand Newish" Truck: 02 Chevy S10 2.2L 5sp. Reg cab 4x2. Badass custom made shifter, foglights, 20% tint, AVS Vent-shades, Stock Intake mods, Electric Fan conversion .
~ 95k miles.
TurboSevenThree is offline
post #5 of 7 Old 11-25-2008, 06:05 PM
do you have any after market things likefog lights,stereo,if so check fuses on them and check your glowplug relay
Early 99 F350-Sold
01 Excursion-Sold
98.5 Cummins-Sold
02 F250- Stock
My Hero
Goose is offline
post #6 of 7 Old 11-25-2008, 06:44 PM
Powerstroke Techie
forddieseldoctor's Avatar
check your voltage drop on the battery cables while cranking should be .5 volts on both power and ground. and also check battery voltage while cranking. just holler if you need more in-depth instructions.
Ford Senior Master Diesel Tech
IF YOU DON'T WANNA STAND BEHIND OUR TROOPS
THEN FEEL FREE TO STAND IN FRONT OF THEM
Meet Double Aught
2000 F250
forddieseldoctor is offline
post #7 of 7 Old 11-25-2008, 06:48 PM
SteveKran's Avatar
Send a message via AIM to SteveKran Send a message via Yahoo to SteveKran
...EDIT...
2003 F250 7.3L Fx4
Find me on AIM under S/N SteveKran
Custom Tuned 6 pos chip
MBRP 4" Turbo Back/Muffler MIA
Quadzilla Commander
Tymar Intake
Zoodad
Wicked Wheel
Leveling Kit
Nathan K5LA's/Dual Compressors/Dual 5 gallon tanks/1/2" lines
SteveKran is offline
