Truck apart for hpop issues - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-24-2014, 09:38 PM Thread Starter
As I was taking our f550 (2004 late) apart for a weak hpop I noticed the map sensor tube was split. The truck was fine save for low icp desired and icp actual numbers at wot (2000 psi). My scan tool can't command the ipr closed to check hpop output so it went to a local diesel mechanic for final diagnostics. Would a leaky map tube cause low icp desired numbers and low icp actual numbers to follow suit? I am at the point where I need an awnser before the pump comes out!
And thanks for the wealth of information here as well.
sask3500 is offline
post #2 of 6 Old 03-25-2014, 07:59 AM
information regurgitator
NYC F-350's Avatar
Quoted: 49 Post(s)
No, it wouldn't.
Please
You could save the life of a sick child
NYC F-350 is offline
post #3 of 6 Old 03-25-2014, 11:08 AM Thread Starter
Thanks boss. Mostly sure it was the case but I hate to miss little details.
sask3500 is offline
post #4 of 6 Old 06-23-2014, 01:36 AM
the map hose being split will cause severe loss of power.i would replace the hose then drive truck and report back.
fatbastardf350 is offline
post #5 of 6 Old 06-23-2014, 01:37 AM
man i'm a day late and a dollar short lmfao...i need some sleep.
post #6 of 6 Old 06-24-2014, 09:32 AM Thread Starter
Yes you do! Tore down and changed HPOP.
sask3500 is offline
