cold start issue - Ford Powerstroke Diesel Forum
post #1 of 3 Old 03-23-2014, 12:56 PM Thread Starter
cold start issue
2000 7.3 - cold start issue. Just replaced all glow plugs, GP relay, 1 injector wiring harness yesterday. Started in garage fine, left outside last night...31 degrees - wouldn't start this morning then I plugged it in for 1 1/2 hrs and it started right up. Any ideas???
Thank you
marauder is offline
post #2 of 3 Old 03-24-2014, 10:15 AM
Injectors?
Spacerz is offline
post #3 of 3 Old 03-25-2014, 10:09 PM
Sounds just like mine. How does your truck run after it is started. Mine is very gutless when it is cold until the temp guage comes up to normal. I have replaced quite a few other parts that needed replacement including some glow plugs, one guy I talked to said to use a test light not an ohmmeter to test, so not sure how you tested yours. I am hoping to test mine again when it gets warm again.
fasteddy is offline
