Fuel Level issue - Ford Powerstroke Diesel Forum
post #1 of 2 Old 03-21-2014, 08:00 AM Thread Starter
Fuel Level issue
weird problem: my 99 7.3 fuel level has been off since i got it, i noticed when i was at quarter tank i ran out of fuel, i drove like this for a while and then one day did a heavy pellet load in the bed and it seemed to be off by half tank after that, i then did a huge pallet run, and now its considered empty by quarter over half tank. Is there something under the bed that can be loose, or get hit by the weight causing the level to be off? Im going to pull the bed soon, wondering what this could be?
awdtsi98 is offline
post #2 of 2 Old 03-21-2014, 08:08 AM
sbluke55's Avatar
Quoted: 525 Post(s)
Garage
Sounds like you foot fell off your fuel pick up. You have to pull the pickup out of the tank. If your in there you might as well do the hutch and harpoon mod.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
