Will not stay running,smoke - Ford Powerstroke Diesel Forum
post #1 of 16 Old 03-20-2014, 04:19 PM Thread Starter
madmax04's Avatar
Hello and thank you in advance , I have an 03 F350 w/6.0, I can't keep this running, constant erratic idle, lots of smoke , I have checked so far:
Fuel pressure 57lbs.
IAT,EBP,Baro 14lbs.
ICP 600-800 cranking
Battery power 12.0
FICM 48.5
FICM sync - YES
REPLACED
ICP,IPR,INJECTORS AND HARNESS,OIL COOLER,EGR DELETE,CMP,CKP,OIL AND FILTER, FUEL FILTERS,AIRDOG II PUMP,POWERMAX TURBO,ECM,FICM,AND CHECKED CAM GEAR IN THE BACK OF ENGINE.AND CUSTOM TUNING FROM SCT
PLEASE HELP YOUTUBE LINK :http://youtu.be/5GDxwIY7wqs
madmax04 is offline
post #2 of 16 Old 03-21-2014, 07:54 AM
any check engine lights? did you check/replace map? (this will cause smoking and rough idle ) if there is a bad sensor or leak in the tube. and have you checked cam position sensor?
awdtsi98 is offline
post #3 of 16 Old 03-21-2014, 09:12 AM Thread Starter
madmax04's Avatar
MAP sensor tube is clean, port in intake is clean, Replaced MAP sensor. Replaced CMP and have signal, will post DTC's soon
madmax04 is offline
post #4 of 16 Old 03-21-2014, 09:13 AM Thread Starter
madmax04's Avatar
It stumbles , stumbles ,stumbles then revs up like nothing is wrong, then it usually dies
madmax04 is offline
post #5 of 16 Old 03-21-2014, 09:15 AM Thread Starter
madmax04's Avatar
and I forgot, this has a regulated return kit on it also,
no air bubbles in the filter housing,FICM sync,I wonder if the tone ring is loose or irregular
madmax04 is offline
post #6 of 16 Old 03-23-2014, 07:33 PM
x148's Avatar
Well 12v is low for one, and did you unplug your icp and see if anything changes.
05 F350
-Sinister EGR Delete
-Banks High Ram
-Blue Spring
-Air Dog II
-K&N Intake
-H&S Mini Max
-Swamps 58v FICM
-03 Turbo
-5" MBRP turbo back
-ARP Head Studs
-Cat ELC1 Coolant
-6" Lift on 37" Toyo M/T
-Detriot True-Trac with 4.56 Gears
-Pro Comp Trac Bars
x148 is offline
post #7 of 16 Old 03-23-2014, 08:29 PM
good ICP, Good fuel psi, good FICM...... Tuner removed?
Looks like a damn injector is hung open with all that smoke. how it the base engine?
I'd do a glow plug mist test and a compresison test
Scumbag is offline
post #8 of 16 Old 03-24-2014, 06:07 AM Thread Starter
madmax04's Avatar
I did unplug the ICP, No change. Compression was good, I have had several people look at it and run diagnostics with no answers, they all look at it then say
"IT SHOULD RUN" , and I have tried with and without tuning!
madmax04 is offline
post #9 of 16 Old 03-24-2014, 08:45 AM
Chatham036's Avatar
Quoted: 131 Post(s)
I bet if you got that Chevy out of your avatar pic, your truck would start working just fine
Comments or opinions expressed by me do not necessarily represent the views of PHP, its management, nor its employees. PHP is not responsible for, and disclaims any and all liability for the content of comments written by me.
Chatham036 is offline
post #10 of 16 Old 03-24-2014, 08:49 AM Thread Starter
madmax04's Avatar
I wish just getting the chevy out of the way would fix it!
madmax04 is offline
