OIL LEAK! - Ford Powerstroke Diesel Forum
post #1 of 7 Old 03-19-2014, 03:08 PM Thread Starter
OIL LEAK!
Looks like I have an oil leak from the corner of the oil pan. It appears to be coming down the backside of the engine where the engine and bell housing meet, right at the back of the starter. Heres some pics..
You guys think its the pan leaking?
PowerstrokeJon is offline
post #2 of 7 Old 03-21-2014, 06:58 AM
sorry bud, your looking at 1000s of dollars to replace that 90$ pan unless you pull a piece of the frame and re weld it in. that is after you verify its your pan leaking.. im in the same boat, although if you havent already do this..
drop your starter when the trucks cold, decrease and lightly sand the pan and area where you think its coming from. then watch for drip. If it ends up being your pan, this is how i fixed mine for like 30$
order the starter kit from por 15
sand the entire pan
clean and prep with de greaser from por 15 kit
layer jb weld over the crack, allow 1-2 days to dry fully
spray the rest of the pan with rust inhibitor
seal with por 15 rust protection.
Jb weld is an old bandage on oil pans for years and years now without issues
awdtsi98 is offline
post #3 of 7 Old 03-21-2014, 07:20 AM
sbluke55's Avatar
Quoted: 553 Post(s)
Garage
I would make sure its not coming from the top of your engine first, ie turbo pedestal or hpop.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
post #4 of 7 Old 03-22-2014, 02:07 PM Thread Starter
I'll check the top of the engine when I get a chance. Thanks for the help.
post #5 of 7 Old 03-22-2014, 02:54 PM
that a 7.3?
Scumbag is offline
post #6 of 7 Old 03-22-2014, 07:10 PM
Quoted: 786 Post(s)
Thats exactly where mine was coming from. It cost me way more than a few thousand, but mi e really needed 250/200 injectors. That helped. Lol:p
Corey@CNCFAB is offline
post #7 of 7 Old 03-23-2014, 02:18 PM Thread Starter
yea it is a 7.3..
