6.0 Oil cooler failure/ is my engine about to blow? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 03-19-2014, 01:00 PM Thread Starter
6LitersofFear's Avatar
I took my truck in for an oil change today, and the tech took it for test drive and he told me that the oil temp was greater than the coolant temp, so my junk is about to blow up. I was going to do head studs, egr's, oil cooler, and stuff once I got the money (in 2 or 3 months), but now that I know I'm on the verge of disaster, should I just park my truck until I can get the work done or can I milk it for a little while? Also, the PO put new injectors in the truck a few months before I brought it, will they be fine in a few months of running like this or should I go ahead and put new ones in again?
6LitersofFear is offline
post #2 of 9 Old 03-19-2014, 01:12 PM
ynpmoose's Avatar
Quoted: 7 Post(s)
How hot was the oil and what was the difference between oil and coolant?
SOLD - 2003 Excursion 6.0L 4x4
ynpmoose is offline
post #3 of 9 Old 03-19-2014, 01:14 PM
Slacker
Evil Eye's Avatar
Quoted: 210 Post(s)
Feedback Score: 4 reviews
It doesn't sound like it has ruptured or you would have a milkshake in your degas bottle. You'll be fine so long as you keep an eye on your oil temp and coolant temp. If you have the option to drive something else, do so. If not, just drive it easy until you can get the parts to get it done correctly. Oh and your injectors should be fine. Your oil pressure is greater than your coolant pressure, so oil will leak into the cooling system. It doesn't usually happen the other way around.
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #4 of 9 Old 03-19-2014, 01:16 PM Thread Starter
He didn't say how hot the oil was but it was a 15 degree difference
03 F250 6.0L 4x4
post #5 of 9 Old 03-19-2014, 01:20 PM
Slacker
Evil Eye's Avatar
Quoted: 210 Post(s)
you are right at the edge. Just keep an eye on it and don't tow and you should be fine until you get the money to fix it.
Shawn Carlson
Proud Navy Vet
Engine Mods:
Fluidampr
4" MBRP Exhaust
MTW Stage 1 Turbo
Exterior Mods:
Evil Eye is offline
post #6 of 9 Old 03-19-2014, 03:31 PM
information regurgitator
NYC F-350's Avatar
Quoted: 49 Post(s)
I'm guessing, since the OP didn't already know he was out of spec, that he does not have the electronic gauges that he needs.
You can't watch those temps without one.
Edge CS, Edge CTS, Scangague2..all good ones..
Please
You could save the life of a sick child
NYC F-350 is offline
post #7 of 9 Old 03-19-2014, 03:47 PM
You should be fine. The coolers will not rupture due to restriction on the coolant side, which is what is causing your high EOT/ECT split. What it WILL do, however, is starve the EGR cooler for coolant, eventually causing it to rupture, pushing coolant into the exhaust. It also is a root cause for localized boiling of coolant, which can push the head gaskets out. So, take it easy, high load situations will make the bad things happen sooner. Ive seen folks get 6 months of driving in cooler conditions with no load and the split you are describing.
winnersdieseltech is offline
post #8 of 9 Old 03-20-2014, 05:54 AM Thread Starter
Thanks for the input guys, i'll just try to leave it alone as best I can and get it to the shop as soon as possible. My plan was to get the edge CS after I had the head studs and stuff done
03 F250 6.0L 4x4
post #9 of 9 Old 03-20-2014, 06:23 AM
johnnybgood's Avatar
Quoted: 79 Post(s)
The time for a monitor is now. Ideally you would have already had one.
If you're short on cash, and have an Android phone, you're in luck. Check out the Torque Application, its a obd diagnostic tool for your phone. Costs $5 for the app, and you also need a bluetooth obd adapter which plugs into your truck and costs anywhere from $9 - $30 depending on brand.
2005 Excursion Limited w/254K+ miles
-Turbo back exhaust -Harley Headlights & Grill
-OEM 20's -FICM Tuner -Torque Pro App
johnnybgood is offline
