Still No replies!!! HELP PLEASE!!! - Ford Powerstroke Diesel Forum
 2Likes
post #1 of 14 Old 03-17-2014, 06:43 AM Thread Starter
Still no responses and need to get with the garage that has my truck...garage is charging 7250.00 for a reman 7.3 long block engine w/ a 3 yr. unlimited mileage warranty...stuff that ive seen online has prices from 3-12k for a long block with the most expensive of them being like super black mamba engines...for a bone stock reman 7.3 am I being ripped off at 7250.00?!?! Someone please respond...don't mind paying the money if im not being ripped off...looking for some advice tho!
SPDLVHero is offline
post #2 of 14 Old 03-17-2014, 06:55 AM
Quoted: 365 Post(s)
Feedback Score: 5 reviews
I guess it depends on what your after..
What is the reason you are getting the whole long block replaced?
Can you have someone fully rebuild yours instead?
Sounds pretty expensive to me considering most trucks with 7.3's dont cost that much LOL.
(unless its a 2003 truck or something)
2005 F250 King Ranch Work Truck.
Studded and Deleted
175/30% Injectors from WARREN DIESEL!!
Barder Stage 2 Turbo
Warren Comp Tranny w/ PI TC
Six0~Stroker is offline
post #3 of 14 Old 03-17-2014, 07:35 AM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 369 Post(s)
Are you getting a reman complete engine? New turbo and injectors? Is that also installed?
Sent from AutoGuide.com App
@loxdce
LoxDiesel is offline
post #4 of 14 Old 03-17-2014, 07:57 AM Thread Starter
Its a reman long block no turbo no starter alternator etc...and no that does not include another 1900.00 in labor...7250.00 is for the engine alone. Started with one bad injector about a week ago had the injector replaced along with the injector gaskets and IDM...lasted a day before it started knocking and blowing white smoke bad...I had it towed to this new shop, first thought was 4 more injectors, 2nd thought was compression check...found 2 and 3 hole with NO compression (zero), so we're at replacing engine.
post #5 of 14 Old 03-17-2014, 08:17 AM
x148's Avatar
If it was me I would find a used motor on craigslist and swap, or have the engine rebuilt by someone else. It would probably be cheaper to have the truck transported to bill Hewitt @ powerstrokehelp lol.
05 F350
-Sinister EGR Delete
-Banks High Ram
-Blue Spring
-Air Dog II
-K&N Intake
-H&S Mini Max
-Swamps 58v FICM
-03 Turbo
-5" MBRP turbo back
-ARP Head Studs
-Cat ELC1 Coolant
-6" Lift on 37" Toyo M/T
-Detriot True-Trac with 4.56 Gears
-Pro Comp Trac Bars
x148 is offline
post #6 of 14 Old 03-17-2014, 09:16 AM
Nope, I would tow it home and think about it more. You can always have it towed back to the shop and have them do the work later on. I would really want to think about this for a while, that is a crap load of money.
Think about it. For 7k + 2k labor. For that you can get a beater car to drive around in the mean time and do the work yourself, and STILL be under 9k. Then sell the beater car when you're done
Six0~Stroker and ynpmoose like this.
Seattle60 is offline
post #7 of 14 Old 03-17-2014, 01:45 PM
LoxDiesel's Avatar
Quoted: 369 Post(s)
A long block is cheaper than that from ford IIRC.
@loxdce
post #8 of 14 Old 03-17-2014, 01:47 PM
That they were going after four injectors before they decided it needs an engine scares me.
winnersdieseltech is offline
post #9 of 14 Old 03-17-2014, 03:59 PM
Sounds high to me. You can get a spare 7.3 truck and swap the motor from one to the other and STILL be cheaper. Might be able to find someone with a beat to crap body and just yank the motor.
Tommycat is offline
post #10 of 14 Old 03-17-2014, 07:07 PM
6.0f250firstcar's Avatar
That price is too high.
I'd search around on google and what not and see what you can come up with.
Ryan
6.0f250firstcar is offline
