huge fuel leak!
So my problems never seem to end. I never got the oil leak fixed, and now the truck is leaking fuel from the motor somewhere. I have been at work for an hour and there is about a half gallon sitting on the ground. As I wAs driving I could hear a hiss sound when I would be on the throttle. I thought it was just cause it is cold outside. I don't get off work until 8 so I won't be able to check out out till then. I just need you guys to tell me what to look for. This is the only vehicle I have nd I can't have this crap. Thnks guys!
lift pump in the valley or the banjo fitting check there first
What is the banjo fitting? Is the lift pump the by the HPOP?
found my leak. the cap ontop of the fuel filter was way loose and squirting fuel out! tightened it up and were good!
