HELP: Stuck in the lot - Ford Powerstroke Diesel Forum
 4Likes
post #1 of 23 Old 03-13-2014, 06:45 AM Thread Starter
i recently just dumped a couple thousand worth of parts and repairs into my 99.5 7.3, it has 187k, no major mods just side exit and chip.. just did glow plugs, relay, etc.
I went to fire my truck the other day and i heard this loud *** noise that sounded like a high speed screw driver spinning. I panicked and turned the key off, then tried again a few seconds later and it started, drove the rest of the night on off on off to gym and a few other places without hearing that noise.
next day i unplugged it, fired it up fine, went to work, left it all day came back at 5 and it made the noise again. only this time it wont start after the second try, its dead in the water.. just keeps going zzzzzzzzzzzzzzzz
it doesnt gargle, pop, shake, vibrate, smoke, or anything. no signs of life aside from a loud noise from under the truck.
A few notes:
the only electrical issues i have noticed is the lights dim when my systems pumpin, which i know is common?
The truck always took a couple extra seconds to start (holding in crank position)
Can anyone outline how to diagnose this issue 100% so i dont blow 200$ on a starter when i need a battery? or is my motor done?
awdtsi98 is offline
post #2 of 23 Old 03-13-2014, 07:15 AM
Quoted: 133 Post(s)
Feedback Score: 3 reviews
I'm having trouble understanding the noise you describe but, could it be the starter gear grinding?
Go look at your Starter - Have any of the bolts that hold it to the engine backed-off?
Is the starter just spinning in place without grinding anything?
Take a hammer and WHACK the starter body a few times and try again maybe...
Heavy_GD likes this.
NoRalPh is offline
post #3 of 23 Old 03-13-2014, 07:24 AM
Heavy_GD's Avatar
Quoted: 1310 Post(s)
Agreed sounds like a starter issue, I'd pull it and check the teeth on both the starter and the ring gear
I though the hammer whack was a chevy thing
GD
Originally Posted by 6.0Stroker View Post
It's Toren. .. don't question it ..
Heavy_GD is offline
post #4 of 23 Old 03-13-2014, 07:36 AM
Mitch
thebierguy's Avatar
Quoted: 85 Post(s)
When I had my 7.3, every once in a while, the starter would make a loud grinding noise like it didn't grab internally. The very next time it would start right away. I suspect it probably is the starter. In would think you would just hear clicking if the batteries are bad.
Mitch
Mitch
2006 Ford F-350 6.0 Crew Cab Lariat Short Box./4" exhaust/SCT X4 7015 (White Noise)/Autometer Boost and Fuel Pressure(Strictly Adapter)/Edge Insight CTS2/FICM Repair.com Complete Wire Kit/08+ Rear Differential Cover/B&W Goosneck hitch/Sinister Coolant Filter/High Idle/Blue Spring/Purchased 2/28/2014
2002 Ford F-350 7.3 Crew Cab Lariat Short Box, SOLD 2/24/2014
thebierguy is offline
post #5 of 23 Old 03-13-2014, 07:43 AM Thread Starter
try to imagine what the starter would sound like without the motor cranking, then amplify it times ten
im going to try to jump the solenoid later just to rule it out, does the key need to be in the run position, in park?
awdtsi98 is offline
post #6 of 23 Old 03-13-2014, 07:49 AM
Heavy_GD's Avatar
thats why I think the solenoid is fine and the starter is either not engaging or the teeth are gone.
GD
Heavy_GD is offline
post #7 of 23 Old 03-13-2014, 07:51 AM
Quoted: 133 Post(s)
The solenoid can't do that though....
It's job is to switch lots of power to the starter. It's doing that - right?
I'm tellin' ya, your starter is either "falling out" or the starter gear or ring gear has a problem
NoRalPh is offline
post #8 of 23 Old 03-13-2014, 08:00 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Yes for once i agree hopefully its just the starter backing out or the gears are gone(hopefully on the starter not the ring gear)
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #9 of 23 Old 03-13-2014, 08:01 AM
over200's Avatar
Quoted: 5 Post(s)
Maybe the vibration from the pumpin system backed a bolt or two out!
Did you find the problem yet?
2000 F350 CCLB 536 k+ miles still runs like a top!
Diablo chip, quickie pedal, valve body, Air Force One air intake, MBRP system, XD Diesels w/ MT ATZ's, KL5H Train Horns / Air Zenith supplied.
over200 is offline
post #10 of 23 Old 03-13-2014, 08:21 AM
Quoted: 133 Post(s)
For once? Dude WTF????
NoRalPh is offline
