turbo issue? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 03-11-2014, 06:29 PM Thread Starter
turbo issue?
my 7.3 just pours out black smoke when cold start till it warms up; then it rolls out heavy grey smoke especially at idle cant get over 2lbs of boost even at WOT
2000 f250 7.3psd cold air intake 4in turbo back exhaust dp f5 tuner
doomachine is offline
post #2 of 3 Old 03-13-2014, 09:24 AM
njnick's Avatar
Quoted: 2 Post(s)
Bad sensor going to the turbo maybe?
2004 F350 4x4 6.0: EGR Delete, Quick Tricks Automotive Looney Tune, Sinister Coolant Filter, Blue Spring Fuel Kit, 4" Turbo Back Exhaust. (Much More To Come!)
njnick is offline
post #3 of 3 Old 03-13-2014, 09:35 AM
my truck used to have similar systems and it ended up being the map sensor tube broke off the sensor.. if your facing your truck look about a half foot to the left of the turbo there is a sensor mounted with a tube going into it from the bottom.. make sure there arent leaks in the line or cuts in the wire. if you have a check engine light it could result in a bad map.. low boost is unfortunately a pain in the butt to diagnose, but if its smoke related id start there.
awdtsi98 is offline
