6.0 first start problem - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-04-2014, 02:49 PM Thread Starter
Unhappy 6.0 first start problem
so I just did studs gaskets 1/2a ficm hpop oil cooler egr delete blue spring with bango bolt upgrade stage 2 afe cold air intake edge juice programmer I just got done with it all last night at 3am like the past 4 nights when I started it it ran fine for bout 1min then started clacking real hard and fast on the passenger side its got a loud thumpin g in the intake also any ideas hopping its not a broke valve
tmontgomery is offline
post #2 of 6 Old 03-04-2014, 06:00 PM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 400 Post(s)
Intake thud doesnt sound good. You may have logded a piece of trash in an intake valve. If you disable it from running and turn it over. Does it turn over consistently or can you notice a miss?
Sent from AutoGuide.com App
@loxdce
LoxDiesel is offline
post #3 of 6 Old 03-17-2014, 01:52 PM
Small bolt or nut lost during teardown made its way into the engine. Sorry. That can make for a bad day.
winnersdieseltech is offline
post #4 of 6 Old 04-02-2014, 07:29 PM Thread Starter
new problem
ok fixed the thumping sound was bent push rods a sticking injector filled cylinder 1 with fuel witch hydro locked it I fixed that got to drive it about 50 miles truck just shut off wile pulling up to a stop sign towed it a mile down the road got it to run off a gas rag but would only run above 1000 rpms scanned for codes found p2614cam position output short to open p2167 crank position output short to open any ideas put both new sensors in today still runs same has fuel and oil plenty of air lol starting to run low on funds
post #5 of 6 Old 04-02-2014, 07:54 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
Check the harness for chafing. Pretty common on 6.0's
dhanna6powerstroke is offline
post #6 of 6 Old 04-03-2014, 06:23 PM Thread Starter
Checked for chaffing, found none. Need wiring schematic to check continuity, at connectors. For PCM fcim. Can anybody help with that?? Maybe email it to me at
theodoremontgomery1988@gmail.com
