6.0 won't start help - Ford Powerstroke Diesel Forum
post #1 of 2 Old 02-20-2014, 04:55 PM Thread Starter
My friend has a 6.0 that will not start. Tested ficm it's 48-48.5 Volts cranking. Icp is 1300-1500 when cranking engine rpm is 250-300. Ipr sits around 50%. Cpm/ckp synch yes along with ficm synch. It cranks sounds like it wants to go but never does. When it sounds like it's catching it shoots a little back smoke. We even tried a bit of propane and wd40 and it wouldn't go with no change. At first we thought it was ficm because it has always had a tough time starting when cold unless plugged in. Bought a reman one still no luck believe it was programmed because the injectors were buzzing. Resold erred original and nothing either. Also tried to unplug icp and nothing. Can anyone help us. What happened before it wouldn't start was it started ran rough no power barely limped it home. Got it home it was at the point it struggled to get up driveway. Shut it down and plugged in and left for a weekend and upon return it hasn't started since. Please help
Davidonmars is offline
post #2 of 2 Old 02-20-2014, 05:01 PM Thread Starter
Injector circuit high cylinder #3,5,8 and glow plug circuit 2,7,8 are the codes that are showing up. The injector codes are new today the glow plug ones showed up for the past week of testing
