99 F350 Oil leak top front of engine - Ford Powerstroke Diesel Forum
post #1 of 3 Old 02-17-2014, 04:37 PM Thread Starter
hey i have been to this site several times and im stuped. I have never seen and oil leak here. Can some one please tell me what im looking at and a guess on how long it will take to fix. the plug or whatever u want to call it back out some how within 2 days it wont turn eather way at the moment. leaks not to terrialbe bad yet.
Alvie Hester is offline
post #2 of 3 Old 02-17-2014, 05:24 PM
Jon_001's Avatar
Plug Leak
If you are talking about the leaking test port on top of the HPOP reservoir it can be fixed.
It appears that your plug has been in and out a few times and somehow the o-ring was damaged in the process.
I use that particular port to vacuum out the hpop reservoir when I change oil. Once I managed to strip the internal hex and my plug was stuck. I used a diamond bur on a die grinder to form a notch on the outside of the circular edge of the plug. then I used a small punch to rotate the plug counterclockwise until it was out far enough to remove by hand.
A new plug from ford is relatively in expensive. If you were planning on installing gauges, the plug that you would remove from the back of the fuel bowl to put in a fuel pressure gauge is the same.
Good Luck,
Jon
Jon_001 is offline
The Following User Says Thank You to Jon_001 For This Useful Post:
Alvie Hester (02-17-2014)
post #3 of 3 Old 02-17-2014, 06:45 PM Thread Starter
thank you so much Jon i thought that was the HPOP but have never had to work on it. (never learned its name) and after i posted this i managed to strip it also... just my luck. again thank you.
