truck rough idle will run for a few minutes then shuts off and takes a while to start - Ford Powerstroke Diesel Forum
Old 10-31-2008, 07:08 AM
99 f350 hard to start after starting has a rough idle seems like it is starving for fuel after starting runs rough for a few minutes then shuts off and takes a while to start again
Old 11-01-2008, 06:31 AM
The Screwy HEUI
Sounds like your IDM is on it's way out. You'll have to perform a contribution test & see what you get for codes. Your IDM is located inside your pass. side feder(which will need to be removed). An IDM will run you appx.$600.
