truck is stuck, need help - Ford Powerstroke Diesel Forum
post #1 of 7 Old 10-30-2008, 06:39 PM Thread Starter
Alright so last night I went to leave work and my truck would not start. The Wait to start sign would come on and then after it would go off my "service engine light" would come on.
Today I went back to the parking lot and my truck started up just fine, but then it started shaking. It started missing bad, and my wait to start symbol was just flickering like crazy. I drove it a little ways and it just turned off. Restarted it and did the same thing. It would drive, but it was missing and would jerk like crazy.
Any ideas to what it could be? I need it to be up and running quick. thanks guys.
dallascwbyfn is offline
post #2 of 7 Old 10-30-2008, 06:41 PM Thread Starter
Oh yea sorry, Its a 2000 7.3
post #3 of 7 Old 10-30-2008, 06:58 PM
assistant director
thbd77's Avatar
wiring harness going thru the valve covers melted it sounds like ...need to scan it
Name-Troy Lincoln
96 F-250 4X4 stroked xcab shortbed 5 speed
01 EXCURSION LIMITED 4X4 V-10 brute force intake dual exhaust
02 EXCURSION LIMITED 4X4 stroked ts 6 position 4" dp and duals hers now
06 F-250 4x4 6.0 auto lariat crew cab short bed Dads ride
thbd77 is offline
post #4 of 7 Old 10-30-2008, 07:06 PM
CoalRollinRoosterCruiser's Avatar
Might just be loose. Not necessarily melted.
But yes, definitely check codes
Jonathon or John Although technically i have a list of nicknames the length of I-95, so call me what ya like
Current Truck--1999.5 F350 ext cab short bed SRW Lariat 4x4 ZF-6. 4" lift, 35's, exhaust, intake, chip, and more.
CoalRollinRoosterCruiser is offline
post #5 of 7 Old 10-30-2008, 07:15 PM Thread Starter
alright thanks guys
post #6 of 7 Old 10-30-2008, 07:44 PM
97powerstroker's Avatar
Quoted: 8 Post(s)
yep,sounds like a short some where to me,if there is power loss to the pcm,it will reboot itself,wts light will flicker,i read it in the manual,i would check the uvch as well.good luck
2002 F-250 7.3 auto CC/SB lariet 115k miles and 100% stock!
1996 F250 460-auto-ext.cab-long box-4.10-152k-10mpg all day running or not.....
97powerstroker is offline
post #7 of 7 Old 10-30-2008, 09:35 PM
-diesel-'s Avatar
Dirty fuel filter?
2KRCSB2WD73335750
-diesel- is offline
