7.3 no fan 911 - Ford Powerstroke Diesel Forum
post #1 of 4 Old 02-16-2014, 10:17 AM Thread Starter
Angry 7.3 no fan 911
Hello group, first post (sorry no time for an intro but I will asap)
I have a 2000 F350 with the 7.3. About a week ago, while moving, the water-pump failed and my serpentine belt shredded. I was able to limp to the new house and park it without damaging the radiator.
I am new to the area, live in the country and do not know anyone who can take me on a parts run. This is the only truck I have. Most of my tools (the good ones) are at my old house - only having a $20 Walmart socket kit and a hammer..
I had a spare belt and was able to overnight in a new pump, thermostat, housing and gaskets from Dieselsite. I went ahead today and started the tear-down. Surprisingly, I was able to get the fan off with a hammer and piece of re-bar and was in the process of taking the 10mil bolts off the pulley when my 1/2in - 1/4 reducer literally broke off in the 10 mil socket! Damnedest thing I have ever seen.
So here I am, drained system, fan and shroud removed and 15 miles away from nearest parts store. All over a $2 reducer.
Question. Can I hook all my pipes back up, refill the system with water and run to and from town without the fan? The shaft/bearing in the water-pump are bad, so it if I put the fan back on it may damage the radiator and shred another belt.
It is about 60 degs and sunny ATM..
Thank you for any advise!!!
Boats72 is offline
post #2 of 4 Old 02-16-2014, 10:35 AM
alaskan155's Avatar
Quoted: 60 Post(s)
i wouldn't but that's just me... you dont have a crescent or box wrench in 10mm to take the bolts off? outside temp doesn't matter(i have overheated a engine in the dead of winter before), i wouldn't run it without a fan, you would have 10mins to 15mins tops before it was a 200 degrees plus and overheating, i have done it before on a old truck.
and those Stanley tools(walmart sucks) invest in a nicer tool-set like craftsman or snap-on, even phittsberg from harbor freight i think is a little be better quality than Stanley.
i have snapped sockets, that reducer twice, and many rachets from walmart....
2002 F250 7.3/JW Tow master 4r100 206k miles
Mods:explorer heater valve, WR GP relay, RiffRAff boots, lariat overhead console, Hydra chip, 6637 mod, 6.0 cooler, AIH delete and isspro2 trans, egt, and boost gauges. 92 gallon aux tank with a total capacity of 130gallons, 1800 mile range
, 4" MBRP straight Piped. 2" Warrior shackles
alaskan155 is offline
post #3 of 4 Old 02-16-2014, 10:44 AM Thread Starter
Thanks for the reply and yes, these tools do suck. I have a full set of craftsman/snapon tools at the other house but no way to get there... again, I was in the process of moving and only had this set to put beds back together lol.
I have no wrenches or better tool - the parts store is closer then my old old house....
Boats72 is offline
post #4 of 4 Old 02-16-2014, 07:52 PM Thread Starter
Got it covered - thanks again
Boats72 is offline
