no sync new FICM - Ford Powerstroke Diesel Forum
post #1 of 7 Old 02-15-2014, 07:14 AM Thread Starter
no sync new FICM
2005 6.0. FICM burned up last week. I have new FICM from FICMfixer. Installed this morning. Monitoring using SCANgaugeII when I cycle the key it shows 42.5 volts which instantly begin to drop. Sync is 0. I replaced the 50 amp fuse in the under hood fuse box. Are there any relays I need to be looking at????????
MoneyPit69
2005 Stock 6.0 Superduty
MoneyPit69 is offline
post #2 of 7 Old 02-15-2014, 07:29 AM
information regurgitator
NYC F-350's Avatar
Quoted: 51 Post(s)
Pop the hood, take the widow off the FICM and check those readings at the FICM itself.
Have you load tested your batteries? Are you sure the batteries are any good?
If your batteries are good, and your FICM voltage check (at the FICM) shows 42.5..have your rebuilt FICM rebuilt again.
Please
You could save the life of a sick child
NYC F-350 is offline
post #3 of 7 Old 02-15-2014, 08:15 AM Thread Starter
Thanks for the quick response. The FICM was tested by the rebuilder at 48+ volts on Thursday. I will check at the window. What is odd to me is that the power starts near where it needs to be and immediately drops off. I load tested the batteries this morning. Just to be sure I charged them to 100% and then load to tested them again. They show good. They are almost new batteries (less than 6 months old). Also should KOEO sync be 0 prior to cranking cycle.
MoneyPit69
post #4 of 7 Old 02-15-2014, 09:18 AM
I Like Shiny Things :)
nighthawk285's Avatar
Quoted: 1783 Post(s)
Feedback Score: 4 reviews
I should have asked this in your other thread, but did you get a rebuilt half-shell, or a full FICM?
2005 King Ranch F-350: Studded and O-Ringed, BPD Oil Bypass, 205/30s, Stage 2 KC Turbo, ODAWG Ported Manifold, 4" TB Exhaust, No Limit Intake, Billet Torque Converter, BPD 58V FICM, BPD Water Pump
2.5" Leveling Kit, 35s, Fusion Bumpers, ProTech Headache Rack, OnBoard Air, and a few other goodies
nighthawk285 is offline
post #5 of 7 Old 02-15-2014, 10:16 AM Thread Starter
The full FICM was rebuilt
MoneyPit69
post #6 of 7 Old 02-15-2014, 10:17 AM Thread Starter
The full FICM was rebuilt and tested out at 48. I still have my original I was sent a rebuilt unit.
MoneyPit69
post #7 of 7 Old 02-15-2014, 03:25 PM Thread Starter
Finally got it figured out. Put the 50A FICM fuse in the wrong slot. As a future reference if any of you do that, you will see about 40 volts on a Scangage and it will quickly drop to 0. Run like a top now.
MoneyPit69
