'00 F350 STARTER KEEPS STICKING - Ford Powerstroke Diesel Forum
post #1 of 11 Old 02-13-2014, 02:47 AM Thread Starter
Hello everybody;
I'm new to the forums here and in need of some help quickly to correct a major problem with my rig and get it moved out of the street. I have a 2000 f350 with a 7.3 in it and it has given me this same problem twice now. It cranks over and tries to start but never actually does, and the starter refuses to kick off until it drains both batteries completely dead. I can pull the key out and it still cranks, and the only wat to get it to quit is to let the batteries drain down. It does it so fast I don't have time to pull the cables off before they're dead.
The solenoid on the fender is a week old, the starter is a month old (had to replace it last time this happened) and almost all of the wiring in the starting circuit has been replaced (had some insulation damage and mouse chews).
Last time it did this I spent a week checking circuits and rewiring everything and it ran perfectly until now. I am out of ideas here and the city is griping for me to move it out of the street from in front of my friend's house where I came to visit.
Any ideas would be greatly appreciated, as I'm stumped. Thanks in advance to anyone who could help me solve this problem.
7.3psCowboy is offline
post #2 of 11 Old 02-13-2014, 05:06 AM
Powerstroke Techie
Quoted: 474 Post(s)
pulling up a wiring diagram and understanding how the entire circuit operates is always a good start. it sounds like an issue with the ign. switch.myou can remove it and test using continuity
the richest ones are not those who have the most, but those who need the least
**i don't use capitals. deal with it**
kaya is offline
post #3 of 11 Old 02-13-2014, 05:26 AM Thread Starter
Thanks a lot. That's about the only place I haven't looked or tested yet. Will check that out and see what I come up with. Much appreciate your help
post #4 of 11 Old 02-13-2014, 05:38 AM
dannanw's Avatar
Quoted: 66 Post(s)
Garage
you have a short to power, aka an electric gremlin....can be hard to find.
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
post #5 of 11 Old 02-13-2014, 08:54 AM
njnick's Avatar
Quoted: 2 Post(s)
Definitely sounds like a short or the starter solenoid could be stuck on.
2004 F350 4x4 6.0: EGR Delete, Quick Tricks Automotive Looney Tune, Sinister Coolant Filter, Blue Spring Fuel Kit, 4" Turbo Back Exhaust. (Much More To Come!)
njnick is offline
post #6 of 11 Old 02-13-2014, 11:17 AM
schlutzer's Avatar
Quoted: 18 Post(s)
Welded/sticking contacts on the solenoid from, low voltage.
Get new batteries because if they are dying that fast. They are your problem.
Low voltage means more heat through the wire.
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #7 of 11 Old 02-13-2014, 06:57 PM Thread Starter
I really appreciate everybody's help here. As of this evening, I have spent today replacing batteries, checking starter and solenoid, replacing ignition switch, and going over everything else again. I reconnected both battteries and starter spun up again and tried to go (with key still off). Unhooked batteries, undid signal wire on relay on fender, and touched grounds to posts again and everything was normal. So I need to find my short between relay and ignition switch. Talked to several people today and I know this is more common an issue than I thought.
post #8 of 11 Old 02-14-2014, 05:25 AM
Powerstroke Techie
Quoted: 474 Post(s)
iirc, there is a harness which is susceptible to rubbing at the steering column. i can't remember off the top of my head what it normally caused, but i do recall this spot as being common.
you don't have an aftermarket alarm on here do you?
kaya is offline
post #9 of 11 Old 02-15-2014, 07:22 AM Thread Starter
No It is stock as far as I know. Will check that next. Thanks
post #10 of 11 Old 02-15-2014, 06:14 PM
midnite rider's Avatar
Quoted: 285 Post(s)
sounds like the switch on the steering column to me. the switch will fail then u get these kind of problems.
-Tom
05 250 KING RANCH CCSB,278k,ARP's,SCT TSX,Atlas 40,STC done,Glowshift FP Gauge,Banks IC System,Blue Spring,Banjo's,CCV mod,Oil Bypass,Diamond Eye 5" Exhaust,Bilstein 5100's,RC Dual Steering Stabilizer,Retro 55W 6k Heads 3k Fogs,Continental Airbags,RSD 48 gal Aux Fuel Tank.
2003 F350 Lariat CCSB, 288K, Everything But Studs.
midnite rider is offline
