fuel bowl fuse blowing - Ford Powerstroke Diesel Forum
post #1 of 10 Old 02-09-2014, 12:21 AM Thread Starter
so my 2003 f-250 7.3 is blowing that oh so common fuse. but it's not the fuel bowl. i've unplugged it the heater.. kept blowing. i switched the 20 amp fuse for a 30 to get it home. but it keeps blowing. the truck started idling very rough. but running completely fine while driving. and only idling rough at random times. now comes the weird part. so it stopped blowing that fuse and now one of the solenoids under the dash just keeps clicking when you turn the key on. it will crank. the wait to start light comes on. the tuner lights up. were going to hook up a scan tool to it today to see what it pops up. but i was wondering if anyone has any quick answers for me. sorry if i left out information. it's late. i just got home form work through the snow in my civic instead of my big awesome 4X4. please help!
RyanMac is offline
post #2 of 10 Old 02-09-2014, 06:48 AM
Quoted: 169 Post(s)
Feedback Score: 3 reviews
We're talking about #30 - right?
And you've already pulled the plug from the bottom of the Fuel Bowl - right?
Well, somewhere there must be a short. I would start by checking the plug and tracing back the wiring to it, over the Valve Covers etc.
Can you locate that noise you hear? The "solenoid"? That would help maybe...
Definitely get it scanned, codes will help a lot.
Oh, Yea, TAKE THAT OVERSIZE FUSE OUT NOW!!!!
NoRalPh is offline
post #3 of 10 Old 02-09-2014, 11:14 AM Thread Starter
it is the c2170 solenoid that continuosly clicks. and even though fuse # 22 is gone. my pcm is still on.... i think thats bad.
RyanMac is offline
post #4 of 10 Old 02-09-2014, 11:49 AM
Quoted: 169 Post(s)
OK, I'm not sure what that is though....
Is that a Relay? Do you know what it controls?
If I assume we're talking about a relay (to me, a "solenoid" is a relay but somewhat mis-described) and it's "buzzing" it is usually caused by a lack of sufficient current to hold it. That can be anything from low batteries, bad connections, or even the relay itself.
In an '03, the two common causes are the Flasher sw, at the top of the column, that's full of crud (because it points "up") and the test for it is to simply use the Turn Signal and that noise stops while it's on.
The second place, that effects All the relays under the dash, is a point under the hood, next to the Airbox, mounted to the top of the fenderwell, under a small black plastic cover marked "High Current". This is where the B+ converts to the Fuseable Links that feed the fusebox and, because of it's poor design, corrodes easily.
Neither of these of course, would cause fuse 30 to blow though....
NoRalPh is offline
post #5 of 10 Old 02-09-2014, 12:06 PM Thread Starter
it's fuse 22. and the solenoid is under the dash next to it.
RyanMac is offline
post #6 of 10 Old 02-09-2014, 12:12 PM Thread Starter
but whatever was causing m idling issue was causing the fuse to blow. nothing to do with the heater whatsoever. it wouldn't blow till the truck idle would start getting extremely lopey
RyanMac is offline
post #7 of 10 Old 02-09-2014, 01:02 PM
Quoted: 169 Post(s)
Do you not have an Owners Manual to show you what those relays are for?
If not, go get one here -> Owner Manuals | fleet.ford.com
See if you can figure-out what it does.
The Fuse that keeps blowing is Fuse #22? That is NOT associated with the Fuel Heater, it is a PCM fuse. When blown you'll lose your WTS light and the engine will not run. You must have a Short somewhere else.
Do you have an SES light that's come on? If so, you would be best to have the truck scanned, with a Professional Scanner, to direct you to what is going on (Unfortunately, it takes a special scanner to retrieve them and the Genreric OBD-II scanners like the Auto Parts stores use don't do us much good...)
NoRalPh is offline
post #8 of 10 Old 02-09-2014, 01:35 PM Thread Starter
i can tell you right now. you wait to start light still works. cuz it always worked. and i don't have an ses light on. it throws no abnormal lights. i'm still waiting for the scanner to show up
RyanMac is offline
post #9 of 10 Old 02-09-2014, 01:41 PM Thread Starter
and it's the idm relay thats clicking non stop.
RyanMac is offline
post #10 of 10 Old 02-09-2014, 03:06 PM
Quoted: 169 Post(s)
OK, did you check the connector under the hood that supplies the FuseBox?
POTENTIAL ELECTRICAL CORROSION if your truck is like mine......
NoRalPh is offline
