2000 7.3 crank no start blowing pcm relay coil fuse - Ford Powerstroke Diesel Forum
post #1 of 7 Old 02-07-2014, 06:39 AM Thread Starter
whateverittakes's Avatar
2000 7.3 crank no start blowing injector driver module relay fuse /wastegate solenoid
Started truck yesterday was leaving work and about a mile town the road truck dies. Had a buddy pull me back to work and found that the fuel heater/wastegate solenoid/ injector driver module relay coil fuse inside the truck was blown. Put new fuse in truck started and went home. went out to start truck this morning and would not start looked at the fuse again it's blown. The fuse is number 30 on the inside of the truck. any suggestions?
2000 Ford F-250 4x4 automatic extended cab lariat
MODS Edge evolution with monitor
5" MBRP Exhaust
S & B cold air intake
Foil delete
wicked wheel
Recon smoked cab lights
3" Reflexxion cowl Hood
Ex-stang bed cover
Headlight & taillight covers
Vent visors
Owner/Operator of
WHATEVER IT TAKES Performance
I drive Ford and part out Dodges
whateverittakes is offline
post #2 of 7 Old 02-07-2014, 07:08 AM
Quoted: 134 Post(s)
Feedback Score: 3 reviews
It's probably the Fuel Heater Element has rotted through. Just unplug the heater from the bottom of the filter housing and replace the fuse. You'll be fine running without it, and in the Spring, you can replace it if you want to...
NoRalPh is offline
post #3 of 7 Old 02-07-2014, 07:09 AM Thread Starter
where is the fuel heater element?
5" MBRP Exhaust
Foil delete
wicked wheel
Ex-stang bed cover
Vent visors
Owner/Operator of
post #4 of 7 Old 02-07-2014, 07:44 AM
Quoted: 134 Post(s)
At the bottom of the Filter Housing
NoRalPh is offline
post #5 of 7 Old 02-07-2014, 08:08 AM Thread Starter
Thanks where is the best/ cheapest to get a new heater at?
5" MBRP Exhaust
Foil delete
wicked wheel
Ex-stang bed cover
Vent visors
Owner/Operator of
post #6 of 7 Old 02-07-2014, 08:30 AM Thread Starter
found dorman part number 904-210 autozone for 39.98
5" MBRP Exhaust
Foil delete
wicked wheel
Ex-stang bed cover
Vent visors
Owner/Operator of
post #7 of 7 Old 02-07-2014, 08:32 AM Thread Starter
Thanks noralph I love this site and the help....
5" MBRP Exhaust
Foil delete
wicked wheel
Ex-stang bed cover
Vent visors
Owner/Operator of
