3-5 psi lpop help - Ford Powerstroke Diesel Forum
Old 10-21-2008, 02:58 PM
Question 3-5 psi lpop help
installed manual gauge and it shows only 3-5 psi oil preasure truck still runs but seems to have a bad miss i have changed the lpop and still the same also have checked the oil bypass in the filter housing need some more info if you can thanks truck is an early 99 f450 7.3
Old 10-21-2008, 03:00 PM
Cynic
How many miles?
Old 10-21-2008, 03:06 PM
Real Men Love Jesus! <><
could be several things. Might be sucking in air by the filter housing, could be a broken pickup tube, clogged pickup head.
Old 10-21-2008, 03:07 PM
Cynic
Didn't your truck do this?
Old 10-21-2008, 03:11 PM
yeah, you know what it was from? idiots who used orange permatex as a gasket on the oil pan. The permatex got ate away, and it leaked bad, plus all the excess that spilled over into the pan had gotten sucked up against the pickup. Scuffy said it looked like a mini orange basketball! haha
Old 10-21-2008, 04:23 PM
truck has 204000 un touched miles its not mine it belongs to a friend and it had not had an oil change in 11000 miles but i changed it first then swaped sensors with the one from my truck i looked and no signs of any permatex arround pan
Old 10-21-2008, 04:28 PM
ADMIN AND TECH
the low oil pressure and the miss are probably not related , where di you hook this gauge in at
Old 10-21-2008, 06:26 PM
the same place the stock one goes
