No Likey Parking Lot Drivey - Ford Powerstroke Diesel Forum
post #1 of 1 Old 02-03-2014, 09:06 PM Thread Starter
1996 7.3
new cps
two symptoms:
1. coming to a red light, stop sign or cruising real slow like in a parking lot while looking for an open spot. the rpm's settle in at 600 as truck slows down. but beware! if you just touch the gas pedal it will kill it. same effect in like an exit ramp from the interstate.
2. cruising at say 60mph. turn on the Cruise Control. Push the Set buttond on the right side of the steering wheel. Beware!!! Dont pull your foot off the gas pedal or it will give you that hard hit like the cps is going out again. only does it once but it will give that "oh shiot" feeling quick.
KentSmoke is offline
