94.5 No start - Ford Powerstroke Diesel Forum
post #1 of 2 Old 01-30-2014, 02:18 PM Thread Starter
whiteout94's Avatar
94.5 No start
So my truck died on me a couple weeks ago. 1994.5 F350 94k miles. Had it towed to a friends shop, he hooked it up to his Snap On scan tool, no codes. Was told to replace the CPS, got a OEM Ford, still no start. Was told it could be the Glow plugs, i personally didnt think so but since i knew the previous owner had cheap ones in it, it was a good time to replace everything. Installed new Beru Glow plugs, Dorman SD UVCH, went over entire harness to look for shorted wires, Soldered and shrink wrapped new UVCH pig tails, double checked to make sure i had each wire wired correct! Got everything back together and of course, NO START! Thought it might be the IPR sticking so i pulled the fuel bowl and IPR, replaced fuel filter 5-6k miles ago, looked inside fuel bowl and sand?/ sediment on bottom and caked on screen between fuel bowl and FPR. Completely blocked! Couldnt even see light through it! Clean EVERYTHING, put back together. Had a friend hook up the GPR and had the washers on the wrong side. Started Cranking and made sure fuel bowl was filling. It was. After it filled it finally FIRED!! WooHoo. but smoke was comming from the GPR so i quickly turned it off and thought maybe it was wired wrong... double checked everything, replaced GPR with a OEM Ford. Still cant get it to fire again... ill go through everything again tonight but any ideas are welcome!!!
1994.5 F350, 4x2, CCLB, ZF5 South Bend Clutch, Diamond Eyes 3" DP-5" Straight Pipe, DIY 6637 intake, ISSPRO EV2 Gauges, 08 Rear Diff Cover, DieselSite Coolant Filter, EBPV and pedestal delete, Riffraff HPx, DIY EFuel, 7.3 SD intercooler
1994.5 F250, 4x2, ECLB, 189k, 5 speed, SOLD
whiteout94 is offline
post #2 of 2 Old 01-30-2014, 02:44 PM Thread Starter
whiteout94's Avatar
Also, I am gettin the WTS light (comes on and goes off as normal), Rpms move while cranking, checked HPOP res and was full, Changed fuel filter, and im getting a little white smoke while cranking
