Coolant Leak 08 6.4L - Ford Powerstroke Diesel Forum
post #1 of 1 Old 01-28-2014, 06:12 PM Thread Starter
Hi guys Im new to the forum and looking for some help. I got my 08 F-250 6.4L truck back in July and and it ran fine. A couple of months have gone by and I noticed a smell of antifreeze after the truck had been running and couldn't find the problem. Now I have noticed a drop of fluid in the coolant reservoir and after getting under the truck I noticed a small amount of antifreeze in on the drivers side of the on the lower end of the motor, but the thing that is confusing to me is that there is also a good amount on the underside of the pipe that leads from the power steering reservoir to the block way up at the top of the motor just behind the fan. Looking for ideas of where this leak might be coming from or if anyone has seen this before. Now I know the 6.4L had radiator issues but I was told when i bought the truck that it had been serviced for all recalls but I don't know of any way to check
6.4LTurbo is offline
Tags
6.4l diesel , antifreeze leak , coolant antifreeze
