02 7.3 intermittent missing with lack of power - Ford Powerstroke Diesel Forum
post #1 of 2 Old 01-27-2014, 11:03 AM Thread Starter
I have an 02 f250 7.3 auto
-intake
-exhaust
-boost fooler
-superchips plug in
-Diablo sport tuner on towing
Alright I am having a problem with my f250. It will miss and get low on put occasionally and blow black smoke (not intentionally lol). It does have the check engine light come on but I don't believe I can read my codes whiles it is running with my reader and it is gone as soon as I shut it off. While driving it almost feels as if it is gelling up but it is running straight #1 with howes. I replaced the fuel filter for kicks but obviously not the issue. I is almost like it drops an injector for a while and comes back. Just wondering if anyone has had this issue I'm trying to avoid dropping the coin and sending it in to get checked out. Thanks
twilen1989 is offline
post #2 of 2 Old 01-28-2014, 04:58 AM
you can still read pending codes. they will be stored because your PCM found a fault and it will check that code the next time it starts. what scanner are you using?
greasemykey is offline
