7.3 Died at light, Full pedal to start - Ford Powerstroke Diesel Forum
post #1 of 2 Old 01-25-2014, 04:38 PM Thread Starter
The problems I am having:
-Lope idle only on the first cold start of every day, fixed by putting light pressure on the pedal
-Truck completely shut off while slowing down to a turn lane, just cranked over and over with no start, dash lights on as if key in ignition on at start...tac moved from 0 to 200-300rpm while cranking (cam sensor okay) by the fifth time of cranking I buried my foot into the pedal and it cranked a few times, spit and sputtered, and finally fired up to get me home.
-Random sputters while driving
-Drove fine for two hours, turned off and went out to start within an hour with no start.
(all separate occasions)
-New starter
-New Batts
-New cam sensor
-New glow plugs + relay
-DP Tuner
-500mi on oil
Any ideas what is going on?
Mpetronek is offline
post #2 of 2 Old 01-26-2014, 06:59 AM
Unplug the icp on the drivers side valve cover,if it starts then its the icp.i had same issue,and dont buy a cheap one!get a ford one,as i went thru 2. Aftermarket ones in 500miles
bullrun is offline
Tags
died , dies , icp , ipr , lope
