update on my 2001 that everyone wanted to know
i put all new 8 injectors in it and i had 3 bad ones that were stuck open , it starts a little hard when cold , runs good , no miss, seems to have power, new turbo , runs realy good , no sevice engine light on , now the bad i found out were the oil is going. it has a lot of crankcase pressure and its blowing it up threw the tube on the driver side, what should i do now,the 3 bad injectors could THEY of washed out the rings and if i run it for a while would they reseal or not ,PLEASE ANY INFO WOULD HELP , THANKS JON
i guess know one has run into this
Just keep
![]() , you will get an answer, you just have to give it a little bit of time, a tech will be in to help you out. |
Bump......Bump
You need to do a compression test on all 8 cylinders.
