Blown rod - Ford Powerstroke Diesel Forum
Old 10-05-2008, 04:10 PM
Blown rod
Have a 1999 powerstroke been blowing gray smoke at startup and would clear up after the motor would heat up, also seemed like it was missing little too, anyway daughter was driving it and I have a hole in the block on both sides, assuming the rods, was wondering if this could have been caused by a bad injector, I have the stage II injectors and would like to put them in a different motor. Not sure what could have caused this, any ideas, Have a truck pull next week end, got alot of work to get ready, thanks.
Old 10-05-2008, 04:24 PM
Cynic
I need info on your setup. Stock injectors and a windowed forged rod block?
Wow.
What tunes are you running?
Old 10-05-2008, 04:28 PM
Do you have anything else supporting the stage 2s, that seems a bit crazy to have blown a forged rod...
Old 10-05-2008, 04:34 PM
Cynic
Sorry, just saw the stage 2's.
But still... need more info. PMR block I can see....
Old 10-07-2008, 06:57 PM
Sorry it took so long to reply, I've been working on the truck, Have regulated return stage II air box, water/meth-- I took the motor out and got another used engine out of a 2000. Not sure what happend.
Old 10-07-2008, 07:19 PM
Talked to a mechanic and he didn't think the injector would have caused this, he said that it must have just spun a bearing, I finished raising the cab and pulled the motor, I swapped the injectors, hopefully I can get the motor back in tomorrow
Old 10-13-2008, 03:09 PM
Got everything back together Friday and was test driving it, got into it 3 or 4 times, brought it back to the shop and seen the tranmission bell housing was broke from the starter up to the top. Pulled the transmission Saturday night and had the housing welded up, Put the transmission back in and welded the driver's side motor mount down and made it to the pull. The motor is vibrating really bad at an idle, but when I get some rpm's it seems to run fine, did pretty well in the pull, when the truck was in low range it seemed like the vibration was in the driveline too. Drives normal down the road even at about 70 mph. Did a contribution test and all cylinders buzzed good, cylinder 8 showed a problem so I pulled that injector and the head of the injector was cracked, so I swapped a head off an injector I had and still runs the same. Does anyone have any ideas?????
